wont start
Old Dec 23, 2008 | 06:43 AM
outlaw1_gt's Avatar
Default wont start
ok a friend at work has a 98.5 Cummins 90,000 miles stock no gauges. he started his truck to warm it up last Tuesday went inside and went back out to find his truck not running. he has fuel but it wont start.. any suggestions?
Old Dec 23, 2008 | 07:24 AM
stkdram55's Avatar
any codes?? How cold did it get?? Fuel might of jelled up on him
Old Dec 23, 2008 | 07:31 AM
outlaw1_gt's Avatar
dont have anything to check codes. dont think it was that cold.. it is now . he also just put fuel in it the day before this happened...
Old Dec 23, 2008 | 07:40 AM
stkdram55's Avatar
should be able to do the key turn to check it
Old Dec 23, 2008 | 07:54 AM
outlaw1_gt's Avatar
didnt think of that since i cant even get mine to do it...
Old Dec 23, 2008 | 07:59 AM
Whit's Avatar
Site Mascot
he may have a plugged up fuel filter,if a transport was dropping fuel when he filled up he may have gotten alot of sediment and plugged the filter
if its cold now he may be gelled up too.................get some 911 fuel additive and when ya change the filter pour some in there while yer at it
Old Dec 23, 2008 | 08:06 AM
outlaw1_gt's Avatar
just changed filter yesterday had fuel filling back up when turned key on
Old Dec 23, 2008 | 12:47 PM
dukeboy_318's Avatar
mine gelled sunday night at 1 degree above 0 at actual temp but with -37 wind chill, ever since the switch to ulsd, ive had fuel gel 4 times in 3 trucks, all with the temps below or at 0 degrees F. it is possible as well that if its getting fuel to the VP, you could have a injection pump problem., also check the fuel heater and grid heater for continuity and see if they actually work.
Old Dec 23, 2008 | 02:49 PM
Whit's Avatar
Site Mascot
you lost yer prime then
crack injector lines 1,3,4 and bump the starter to run the lift pump.....do this 3 times and then tighten the lines down then she will run
Old Dec 23, 2008 | 03:27 PM
outlaw1_gt's Avatar
ok ill talk to him in the morning and we will give it a try
