Gutting your AFC?
Old Dec 22, 2008 | 07:12 PM
smokedout's Avatar
Default Gutting your AFC?
Whats the negatives and postives about gutting your AFC?
Old Dec 22, 2008 | 08:09 PM
prromine's Avatar
You will get all your fuel before the turbo gets the air in. More heat and smoke.
Old Dec 22, 2008 | 09:41 PM
sstockton's Avatar
I wouldn't gut the AFC, IMO tuning it is a better option. You can grind the foot of the AFC lever, switch the position of the washer around the diaphragm, and tune the star wheel or replace the spring to change spring tension and pre-load for when your fuel comes on.
Sean
Old Dec 22, 2008 | 10:25 PM
Lil Dog's Avatar
Running without the AFC sounds neat but its alot of drive by feel. You don't have boost to fuel control and its pretty easy to "put out the fire" with alot of low end fuel.. As was said before, changing the AFC foot geometry for full rack travel and or/changing the spring for better tuning is my recommendation.
Old Dec 23, 2008 | 04:24 AM
hereismylife's Avatar
Default What does grinding the foot do?
I am wondering how does the grinding the foot help?
Old Dec 23, 2008 | 05:02 AM
jasonw's Avatar
More rack travel, if you've got the plate for it. With some plates, grinding the barrel/foot won't do anything, simply because the profile is too conservative. A #0 plate is the only time I could see one grinding the barrel/foot for max travel. I think it's 21mm or something around there.
my97-6gun
May 3, 2015 09:43 PM
easttn12valve
Jan 17, 2015 11:09 AM
NiNjAassasin545
Dec 2, 2014 11:40 PM
xj_crawler
12
Nov 20, 2014 10:17 PM
SMatyac
Nov 4, 2014 10:29 PM
