Noisy 4 wheel drive
Old Dec 20, 2008 | 08:58 PM
Tyber's Avatar
Default Noisy 4 wheel drive
Just curious as I am still relatively new to owning a 4x4 and it has been getting down to -30C here in Calgary. I have noticed a bit of a clunking when I engage 4x4 high and low ranges, but have only noticed it since the temperature has dropped. I am assuming that it is just because the fluid has gotten so thick from the cold. What do you think??? Oh and I did check the fluid in my front diff and it is fine.
Old Dec 20, 2008 | 09:00 PM
wildbill's Avatar
Bad u-joints, transfer case could be getting a little sloppy. Is it a floor shift or a **** on the dash?
Old Dec 23, 2008 | 05:19 PM
Tyber's Avatar
It is a floor shift, and now that it has warmed up a little the noise is a lot less. I have had the truck since May, and have never noticed any noises before. It shifts in and out of forr wheel no problem and doesn't kick out on its own ever.
Old Dec 23, 2008 | 06:54 PM
wildbill's Avatar
If your going from high to low, you pretty much have to stop first, put the transmission into N, then go from L to H, or vice versa. To get it to shift out of 4H after putting it in 2H, let off the throttle a little bit. It should then pop out. If not, goose it slightly.
Old Dec 23, 2008 | 07:17 PM
Tyber's Avatar
Yes, I know that, but that doesn't explain the noises after I engage the system, As I sad I do not have any issues shifting the system into 4 hi or 4 Lo
Old Dec 23, 2008 | 07:44 PM
wildbill's Avatar
Is it kinda like a grinding noise, or does it sound like a loose chain?? When was the last time the fluid was checked or changed out?? Sorry I had to ask.
Old Dec 23, 2008 | 08:07 PM
Tyber's Avatar
Honestly kind of a hard one to identify, it is almost like a grinding noise but more like a contiuous clunk. I actually just checked the fluid 3 days ago as I was afraid that it may have been the culprit, but my levels were good, and the oil didn't seem burnt and the magnetic drain plug only had a slight coating of metal, which as I was told is normal wear and tear.
The oil was the consistancy of really think pancake syrup though, so i thought maybe that was the cause....keep in mind it has been -30C here, which is about -15F
Old Dec 23, 2008 | 11:17 PM
wildbill's Avatar
Dodge likes to run ATF+4 in the t-cases, which I was told was dino oil. You can run any synthetic oil in them, I believe.
Old Dec 23, 2008 | 11:27 PM
TCBROWN's Avatar
does the noise only hapen when you engage it ir does it continue as you drive
Old Dec 24, 2008 | 01:19 PM
Tyber's Avatar
The noise is only while the truck is moving, but as I found out today, now that itwarmed up drastically outside, it is being caused by the cold....The sound has stopped, and I talked to 4 wheeler shop and they said that it is common for the front axle to be loud in the cold that we get. Thanks for all your help
cutthroatxxx
Jun 22, 2015 10:16 PM
Mar 19, 2015 08:10 AM
6.5dieselman
Feb 26, 2015 04:45 PM
MAC4232
Jan 28, 2015 01:46 PM
2002cabandchassis
Oct 29, 2014 01:59 PM
