fuel pump
Old May 13, 2007 | 11:58 AM
iforge03's Avatar
Default fuel pump
a friend of mine has an early model duramax (99 or 00). it isnt getting fuel at the fuel filter so he wants to check the fuel pump. i havent had a chance to check it out so i thought i might ask someone where the fuel pump is. he cant find it so im guessing in-tank. any help is greatly appreciated.
Old May 13, 2007 | 12:31 PM
DBogo's Avatar
its got to be a 01 thats the first year, and its a lift pump it should be mounted somewhere outside the tank i dont beleive duramaxes are in tank, someone with a duramax might be more helpful then me
Old May 13, 2007 | 01:33 PM
iforge03's Avatar
ill tell him to look around a little more. thanks
Old May 13, 2007 | 01:45 PM
DangerousDuramax's Avatar
The DMax doesnt have a lift pump or pre-engine fuel pump. It uses the CP3 solely to fuel the engine. There are a couple of inherent traits of the DMax when it comes to fuel issues. 7 out of 10 times it can be fixed by just changing the fuel filter. Most people drive on them too long and then the truck starts running bad because it's getting plugged up. Being that it's on a 00 (first year of the DMax) I would suspect that he has gotten some trash at the pick up canister in the tank. It sits right down on the bottom of the tank and has both the pick-up and return there. Tell him to crack the bleed screw on top of the filter housing and see if he can get fuel using the manual hand pump. If not, I would drop the tank and see if there is trash at the canister or if the pick-up tube fell off, deteriorated, or plugged.
Old May 13, 2007 | 01:56 PM
DBogo's Avatar
see why someone with a duramax would be more helpful... hey i tryed
Old May 13, 2007 | 03:23 PM
dozerboy's Avatar
Also the seals in the housing or the housing it self can crack, but I haven't head of anyone being able to get it primed in those cases. CP3 do go bad, but I don't know how one would check it a vac gauge?
Back-in-Black
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
bud0994
9
Jun 8, 2015 06:15 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
Gm3500
May 7, 2015 11:01 AM
