WOT Problems
Old Dec 20, 2008 | 03:06 PM
justviper1's Avatar
Default WOT Problems
Anyone have any idea of what could be causing this...when I gouge the truck wide open it will shut off. The turbo timer will stay on until I cancel it by pulling the key out and hitting the gas pedal and then if I try to start it, it will start right back up. It is driving me nuts. I have the dyno2_4k file in the adrenaline and then changed it to the compf but it didn't seem to make a difference. Im not sure if it is adrenaline related or not.
Old Dec 20, 2008 | 03:10 PM
Benjamin's Avatar
Bombardier
does it do it if the adrenaline is completely removed from the truck?
Old Dec 20, 2008 | 03:24 PM
busta's Avatar
i once had a problem with the old comp f tune shutting the truck off during warmup mode switched to the comp2_4k and runs great even tho i still don`t have a fp reading
sounds like you need to adjust some settings for for tt and your fuel settings
Old Dec 20, 2008 | 05:35 PM
dukeboy_318's Avatar
sounds like another adrenaline box problem, remove the box and see if it fixes it
Old Dec 20, 2008 | 05:47 PM
cummins24's Avatar
Probably an ADR problem, I would say test your fuel pressure but from your signature it looks like you already solved the fueling problem.
Old Dec 21, 2008 | 12:58 AM
justviper1's Avatar
I know it isn't running out of fuel because if it was it would stumble and then die and would be really hard to start. After it shuts off you have to wait about a minute after turning everything off and then it will start back up. Tomorrow I will remove the adrenaline and see if that fixes it. I really don't want to go back to stock though.
Old Dec 21, 2008 | 09:49 AM
cummins24's Avatar
After having the adrenaline stock just sucks
Old Dec 21, 2008 | 10:27 AM
tearin_it_up_everywhere's Avatar
I had the same sort of problem at wot it would run great but as soon as i let off it would die.
Old Dec 21, 2008 | 10:37 AM
busta's Avatar
ya need the pulse to set everything up for the way you want to drive it
Old Dec 21, 2008 | 11:14 PM
justviper1's Avatar
Unhooked the Adrenaline today and the truck then did not quit at WOT. It must be something in the box that is causing it. I guess I am going to have to call quad tomorrow and see what they can do for me. This sucks!
