stock fuel pressure on 06
Old May 13, 2007 | 11:57 AM
ramfreak01's Avatar
Default stock fuel pressure on 06
what should it be? i'm running 7 psi right now idling, 5-6 cruisin, and 2-3 full throttle with the tst on 3-2. do these numbers sound right? i just finished up the install today (only took a month). i'm using isspros with dieselmanors isolator. should i get ride of the isolator? its above the mirror, only reason i'm using it as of right now
Old May 13, 2007 | 12:12 PM
Im no third gen expert....but I think thats about where they run...
Third gen guys, please correct me if Im wrong.
Old May 15, 2007 | 05:21 PM
Dodgezilla's Avatar
Mine sits at around 8-10psi during normal driving. It drops to about 4psi under hard throttle....
Mine's an 07
Old May 16, 2007 | 08:48 AM
JesseRohr's Avatar
FormerVendor
Mine stock was 11 PSI then dropped down to about 5 @ WOT on my 05.
Old May 17, 2007 | 11:07 PM
Luvnacummins's Avatar
Those numbers are normal!!
Old May 19, 2007 | 10:08 PM
95ram's Avatar
My 06 is at 9 psi at idle, 8 cruising at 40-80, and I can pull it down to 0 with the smarty on 9. So you sound good to me.
Old May 23, 2007 | 08:12 PM
Truevalue Truck's Avatar
Mine was running 7-8 @ idle....would drop to 0 @ WOT with the Xzillaraider on #2 or #3. Just had the FASS-HPFP-150 put on today at New Era Diesel and its sitting @ 12psi. The most I could pull it down to playing around today was 9 psi @WOT on level #3
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
