Price Quote - Request A Price This Forum is for Requesting Price Quotes - Upon Your New thread All Participating Vendors & Distributors Will Receive a Private Message Notifying them Of your Thread - You May Opt Out of this Option
Pop off Valve Needed
Old Dec 19, 2008 | 07:41 PM
04 Stroker's Avatar
Default Pop off Valve Needed
Needing price quote on a electronic pop off valve for 2004 F-250. Having turbo surge problems.
Old Dec 23, 2008 | 07:40 AM
cumminalong's Avatar
You do realize that a BOV doesn't quite work the same on a diesel as it does on a gasser, right?
The reason a BOV is needed on gasser is because of the butterfly on the throttle body slamming shut when you get out of the throttle and the air having no where to go.
Diesels don't have throttle bodies or butterfly's so the BOV isn't what's needed.
If you are surging, you are having wastegate issues / drive pressure issues.
Old Dec 23, 2008 | 06:49 PM
04 Stroker's Avatar
Was told there is no wastegate on the 6.0 litre. Im not sure what i need exactly Elite Diesel Eng. said a bov would fix this problem but they are pricey through them was just hoping someone on here could give me a better price.
Old Dec 24, 2008 | 08:54 AM
Correct. The variable vanes on it act as the "wastegate". There is a pigtail that runs to the solenoid that controls the vanes.
If those don't react fast enough, you get the turbo bark.
It's caused by the pressure difference on the intake and exhaust sides of the turbo.
You go from having lots of drive pressure, to none, but the turbo is still trying to spin and compress air.
That "bark" is basically a see saw action between the compresor and turbine wheel fighting to see who's making more pressure.
A BOV won't really solve this problem on a diesel. There is no huge increase in pressure on the intake side casued by a closing throttle body. The cause is more due to the loss of drive pressure.
Only way to really avoid it is to not jump off the throttle too quickly.
RA113024
Mar 13, 2016 07:42 PM
jeremiah1
Jul 21, 2015 06:35 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
woodsman27
Oct 26, 2014 02:13 AM
