fp gauge install help
Old Dec 16, 2008 | 12:38 PM
biged681985's Avatar
Default fp gauge install help
alright guys, i bought a fp gauge and neeing help figureing out how to get put in. i have an airdog 150 on my truck so i cant go to the fuel filter. do i need to buy a T and put it in the 1/2 fuel line or where do i need to put it. thanks in advance for the help.
Old Dec 16, 2008 | 04:14 PM
Mr.Krabs's Avatar
I'd just get a T in the line wherever you want to put it,somewhere out of the way,I did not bother to use a isolator,just make sure the dang thing don't leak cause' it takes forever to get the stink out of your cab....
The line to the FP gauge should be pretty small,I mashed mine a little so the vibration from the VP would not hurt it,though I'm not sure that is strictly necessary.
I just ordered one of these to T in with Glacier Diesel Power - Product Detail
But you could use anything like that you wanted,make one up from the hardware store with a Female T and a couple of barbs if you want.
Old Dec 16, 2008 | 06:18 PM
Ed ke6bnl's Avatar
there is a plug you remove and take your readings from that port. I ran a line to a snubber and a mechanical gauge and tee to a digital fuel pr. guage Ed
Old Dec 16, 2008 | 07:38 PM
what plug were you speaking of ED. i know there was supposed to be one on the stock fuel filter but mine is MIA.
Old Dec 17, 2008 | 01:47 AM
Ed ke6bnl's Avatar
I would have to go under the vehicle and check but I believe I removed
an allen head plug in the aluminum block of the airdog. Let me know if
you find it if not I will go under the truck and check it out. Last
resort I would call Charles the owner of air dog at 573 2308838. let
me know and I will help you out
Old Dec 17, 2008 | 10:21 AM
Mr.Krabs's Avatar
I guess I should have seen he had an airdog and no fuel filter canister..
Biged there is a picture in your install manual,it's where the warning light pressure sender can be installed
huntman7
Sep 4, 2015 04:49 AM
MrCat4974
Mar 23, 2015 11:30 PM
99stackedpowerstroke
Feb 7, 2015 10:58 AM
450r racer
Nov 14, 2014 05:11 PM
scottxmorris
Oct 8, 2014 02:14 PM
