??Boost
Old Dec 15, 2008 | 04:05 PM
4x4DREAMER's Avatar
Default ??Boost
I talk with an agent at bullydog about the settings for my truck.The boost setting seems low and everytime I take off it defuels quickly.My ? is I have my boost set at 20,could I raise this setting without hurting the turbo or engine?
Old Dec 16, 2008 | 08:40 PM
brad2003's Avatar
im not shure but i do no i have the banks big hoss bundle i thought it would give me alote more then it did though i had a 7.3L and loved it had a supper chip for it it gave me about the same pawer i think
Old Dec 17, 2008 | 12:10 PM
Diesel Powered Rocket's Avatar
When stock, my truck had 26 - 29 inches of boost jumping into traffic. Have you done ARP studs yet?
Old Dec 17, 2008 | 03:37 PM
4x4DREAMER's Avatar
No not yet....I am going to get the extended warranty at tax time and ford said that when the studs go bad, the extended warranty would cover it. So just hoping nothing happens till then..
Old Dec 17, 2008 | 10:52 PM
YMMOT's Avatar
My truck would spike at 28 psi and the hang around 25 to 26 under heavy loads when stock
Old Dec 18, 2008 | 08:46 PM
strokedout07's Avatar
when the viens were stuck on my turbo it would hit 35 all day long but after ford fixed it it came down to normal
Old Dec 18, 2008 | 11:33 PM
atrd86's Avatar
My truck hits 27psi with it in stock mode when I put it to the floor. Even when I'm in extreme my egt's start getting a little excessive before my psi becomes a problem. I havent done the studs yet either and havent had a single problem with the truck yet, motor or turbo.
Old Jan 4, 2009 | 03:27 PM
StrokerDude's Avatar
I hit 32 lbs all the time if I lug it a little with the TC locked. The best thing you can do for your truck right now is get rid of that BullyDog. They are good for dodges but suck for Fords. Get an SCT with custom tunes from Innovative, those tunes are very safe for the truck and the best you can do for a 6.0 right now.
