Tire Size
Old Dec 15, 2008 | 03:07 PM
K50's Avatar
K50
Default Tire Size
Hi guys,
Does anyone know what the maximum height and width of tires is that I can run on a stock 4x4 2500HD? My truck is bone stock, and I hate the tiny tires that GM always puts on their 3/4 ton and larger trucks. Eventually once I get the truck lifted I'll look at some 32's, but for now I'm just wondering what the max I can get away with is on the stock 16"x6.5" rims.
Thanks
Old Dec 15, 2008 | 03:57 PM
Johnny Cetane's Avatar
I had 305/75r16s (33"x12") on my truck until recently. I had to crank the bars up almost all the way and trim the rear edge of the lower valance but they did fit without rubbing.
Old Dec 15, 2008 | 04:12 PM
K50's Avatar
K50
holy crap...those are big tires.
Was that on stock 6.5" wide rims?
Do you think I could I run a 31" tire without cranking up the bars?
Old Dec 15, 2008 | 04:19 PM
They were on the stock rims for a while and just scrubbed the sway bar on real tight turns but didn't rub at all when they were on my MHT wheels.
You should be able to fit a 265/75R16 without cranking them. I think you can even get a 285 (about 32") under there without touching the bars.
Old Dec 15, 2008 | 04:33 PM
K50's Avatar
K50
Thanks Johnny
Old Dec 15, 2008 | 08:56 PM
tomc983's Avatar
my truck came with 265s and i have no rub
Old Dec 16, 2008 | 10:37 AM
Oilfield_Mafia's Avatar
you can get 33.5" tires on a stock LBZ.. I have my bars cranked up all the way with my 305/55/20 Nitto Terra Grapplers.. they measure out just a shade over 33.5" and only rub at full lock.. just a tad..
Old Dec 16, 2008 | 12:06 PM
2500HeavyDuty's Avatar
285/75/r16 is pretty big even for them 6 inch wide rims any bigger they will look like donuts.
265/75/r16 is abut 31 inches tall and u can fit them pretty easily on stock height.
Old Dec 20, 2008 | 06:36 AM
Big_Johnson's Avatar
I'm gonna be puttin 33" nitto terra grapplers with 20" rims on my 03 2wd. I have my tortion bars cranked up so that right now it's 10" from the top of the tire to the wheel well in the front. in the back i will have no problem fitting the 33's in the front however the guys at the tire shop say i might rub a little if i'm goin down a hill and making a sharp turn. So i think you should be good to go. my truck sits higher than any stock 4wd i sit next to so just crank up the tortion bars and you should be good to go
BTW, I was informed by someone on here...^^^ not to crank the tortion bars more than 2 inches or you will have to get your tires realigned.
salty4life
Aug 20, 2015 10:46 AM
B737 Capt
Jun 9, 2015 06:34 AM
dallasca
28
May 26, 2015 12:58 AM
LB7yooper
Mar 23, 2015 11:33 AM
LikeTheFabric
Ford Powerstroke 2011-Up 6.7L
Mar 10, 2015 01:18 PM
