Quad Pulse Questions and Answers
Hey guy's I just got my pulse and hooked it up. Now i have some ?'s. What is the difference between Vehicle speed and true speed.
And can you switch levels as far as when you have a program in say ADR2000. Can you go from level 1 (just timing) to say level 8?
in the attached image you see the egt,boost,fuel and water readings and if you look over to the right you see a 3 in between 2 arrows that is telling you what level it is on
you use the middle 2 buttons of the 4 on the right to go up or down on levels
lil bigger pic for ya here.. it's in warmup mode right here, but you can see the pl# in the middle to the right of the display..
to change PL use the 2 middle buttons with arrows next to them
top button is menu, bottom is enter
True speed is how fast the vehicle is actually going.
If you have oversize tires your true speed will not match the vehicle speed and you will have to use the tire size settings to get the True speed to register correctly.
Aug 25, 2015 07:30 PM
Nov 28, 2014 09:50 PM
Nov 12, 2014 08:10 AM
