vp44
Old Dec 10, 2008 | 09:32 PM
Blue01cummins's Avatar
Default vp44
is there any way to modify a vp44?
Old Dec 10, 2008 | 10:26 PM
cummins24's Avatar
Do you mean turn it up like on the 12 valves? No, the VP44 is an electric pump meaning the only way it can push more fuel is through the use of a chip or programmer which tricks the ECM to make more power. Some chips like the Edge Comp and Quadzilla Adrenaline may require you to tap the injector pump wire which gives you more HP than chips that don't require you to. I think tapping the wire is as close as you can get to modifying the VP itself.
Old Dec 10, 2008 | 10:58 PM
SNACKPACK's Avatar
rich, get a BDVP or a monster.. why don't you throw on the hot rod vp you got?
i dont know of any internal upgrades to do to them. maybe change the keyway for a different timing advance????? but that is beyond me
Old Dec 10, 2008 | 11:02 PM
i want to mod this one like drill some stuff out and other stuff just wanted to see if anyone ever has
Old Dec 10, 2008 | 11:04 PM
SNACKPACK's Avatar
i think you just gotta buy the big pumps, or go to a P-pump. do you still have the HRvp?
Old Dec 10, 2008 | 11:52 PM
yea i do todd
Old Dec 11, 2008 | 02:20 AM
SNACKPACK's Avatar
throw it in there man.
Old Dec 11, 2008 | 02:53 AM
SPEAKSUP's Avatar
Yeah throw that HRVP in there Blue
Old Dec 11, 2008 | 11:14 AM
dukeboy_318's Avatar
agreed
Old Dec 15, 2008 | 04:40 PM
tearin_it_up_everywhere's Avatar
My hrvp has different valves inside the rotor so it will have more fuel going to the injector. more fuel=more power and smoke. I dont even run my pump wire tapped because it can flow to much and back flow and cause your rotor head to lock up. It is always best to run injectors when you have your wire tapped just for that reason. I found out the hard way. It hurts the wallet.
