Agricultural & Lawn Equipment Discussion of Diesels Used in Agricultural - Tractors , Lawn Mowers , Combines , Ag Equipment , Zero Turns
Power increase on John Deere??
Old Dec 10, 2008 | 01:07 AM
BlackPearl03's Avatar
Default Power increase on John Deere??
Anybody have any input on how to increase the power on a John Deere 3010?
Any help greatly appreciated, Thanks.
Old Dec 10, 2008 | 01:30 AM
stkdram55's Avatar
what year is it?? I know TS has there AG chips if it is new enough for the fuel system to be electronic
Old Dec 10, 2008 | 01:32 AM
unfortunately it a 1962 model, so that is out of the question. Its going to have to be all mechanical mods.
Old Dec 10, 2008 | 01:37 AM
stkdram55's Avatar
yeah it will definately have a mechanical injection pump on it, your best bet is to find the injection pump and look for a screw or something that has what looks like baling wire running thru it to keep someone from messing with it and chances are that is your fuel screw...now i would say to have the engine running when you start tweaking this in case it starts to run away or do something you dont want it to and you can return it back to normal fast, and probably have a piece of plywood to put over the air intake incase of runaway too
Old Dec 10, 2008 | 01:39 AM
hmmmm... i know exactly where that is located. I think i just might look into that. Any other ideas, maybe additions to it or something?
Old Dec 10, 2008 | 01:44 AM
stkdram55's Avatar
Nitrous!?!?!?!?!
It really depends on what ya want to do with it, you could make ya custom air intake, get injectors made or cut for it, add a turbo or get a bigger one if it already has one
Old Dec 10, 2008 | 01:46 AM
it doesnt have a turbo. I had actually considered installing a turbo. Im not trying to do tractor pulls just get some more juice for out in the field. Its got an oil bath air cleaner, and seems to get plenty of air.
Old Dec 10, 2008 | 01:47 AM
stkdram55's Avatar
really air and fuel is the way to make power so more air and more fuel will get you more power
Old Dec 10, 2008 | 01:55 AM
That i do know Im just trying to pull from others
Would any turbo work? And would it work with the oil bath filter?
Old Dec 10, 2008 | 02:04 AM
stkdram55's Avatar
that i would not know im sure someone might maybe one of the old timers on here you would however probably need a pretty small turbo since your not really pushing that much fuel
