Trouble Codes
Old Dec 8, 2008 | 07:56 PM
bobracing32's Avatar
Default Trouble Codes
ive got a 1693 and 0500 anyone tell me what these mean or if they are bad.
Old Dec 8, 2008 | 07:58 PM
Jazz's Avatar
You can find your codes here https://www.dieselbombers.com/codes.php
1693 is a companion code nothing to worry about 0500 is no vehicle speed sensor signal
Old Dec 8, 2008 | 08:04 PM
Mr.Krabs's Avatar
Whatcha drivin?
Old Dec 8, 2008 | 08:10 PM
01 6 sp cummins edge with attitude, intake, custom exhaust
it just threw the engine light on and i got a little worried but those arnt anything to worry about
Last edited by bobracing32; Dec 8, 2008 at 08:10 PM. Reason: Automerged Doublepost
Old Dec 8, 2008 | 08:22 PM
TheNatural31's Avatar
0500- No vehicle speed sensor signal
1693- A companion code....need to dig deeper and read it with a scanner
Old Dec 8, 2008 | 10:30 PM
What he said.
Was that read with a scanner or key on/off thing?
Old Dec 9, 2008 | 09:10 AM
Mopar1973Man's Avatar
P1693 cause by the P0500...
P0500 is cause from spining the tires... The ABS brakes monitor both the front and rear axles. But when your roasting the rear tires and the front axle isn't twisting the computer has a hard time understanding how can half a truck be going 50-60 MPH and the front axle is not moving...
Old Dec 9, 2008 | 10:13 PM
on off thing,also i was pushing snow and i could have been in 2 wheel i use that in tight places instead of 4 wheel hopping
Old Dec 10, 2008 | 10:41 AM
See... There is your answer... The 2WD was given you the steering but the rear tire were spinning... ABS computer just can't understand that...
Just clear the code and go on... But If you don't have a scanner it will clear on its own. It not a serious error nore will it effect your performance or anything...
asajay
Sep 10, 2015 12:08 AM
longhorn12
6.7L Performance
Aug 29, 2015 01:28 PM
KimberlysTruck
Mar 5, 2015 06:28 PM
DSM1988
Jan 18, 2015 11:11 AM
Altonlee
9
Oct 8, 2014 02:31 PM
