Can someone explain the LMM, LBZ, etc mean
Old Dec 8, 2008 | 07:56 PM
HeavyChevyDMAX's Avatar
Default Can someone explain the LMM, LBZ, etc mean
I know theres one for certain models but i dont know which one goes to with model... also I have an 07 duramax classic... What L would it be haha, prob should know this but i dont.
thanks for the help, jim
Old Dec 8, 2008 | 08:05 PM
Rttoys's Avatar
Classic will be - LBZ
New body style- LMM
Look at the tag in your glove box to confirm. RPO code LBZ will be there.
Old Dec 8, 2008 | 08:06 PM
oh ok thanks man
Old Dec 8, 2008 | 11:05 PM
Oilfield_Mafia's Avatar
Jim, to help brake this down even further, 01-04.5 Duramax is an LB7, 04.5-06 Duramax is LLY, 06-07 Classic, is LBZ, and 07.5+ is LMM
Heres a detailed breakdown of each motor
https://www.dieselbombers.com/durama...tml#post182396
Old Dec 8, 2008 | 11:09 PM
ScrmnEagle's Avatar
Jim,
I believe in the 8th digit if your vin will identify the generation of Duramax you have. Yours should have a "D" thus idenitying the LBZ generation. The 07.5, NBS, have the LMM generation. Not sure what the designator in the VIN is though. Hope this helps
Old Dec 8, 2008 | 11:42 PM
2500HeavyDuty's Avatar
07 classic is lbz
Old Dec 9, 2008 | 07:08 PM
Originally Posted by ScrmnEagle
Jim,
yea it is a D... thanks man, and to the others that posted
Old Dec 10, 2008 | 06:08 AM
LOGANSTANFORTH's Avatar
LB7 was from 2001 to 2004.5
1st generation LLY was from 2004.5 to 2006
this engine is not the same as the 2nd generation LLY. you could get both LB7 and LLY with the 5 speed auto Allison or the 6 speed ZF manual
LBZ and 2nd generation LLY was 2006 to 2007.5
you can only get the second generation LLY in 2006 and it only came with the ZF 6 speed manual. it is nothing more than a detuned LBZ. (same block, crank, heads, blah, blah, blah, just different computer tuning) the LBZ is only available with the 6 speed automatic Allison. the LBZ was the only engine offered in 2007 to 2007.5
LMM is 2007.5 to present
PIECE OF S*&T DPF......nuff said.....
Old Dec 10, 2008 | 01:08 PM
theres a few lly 6 speed autos out there
Old Dec 11, 2008 | 05:08 AM
id like to find one......rare truck......
