Twin Turbos
Old Dec 8, 2008 | 12:52 AM
baseball31's Avatar
Default Twin Turbos
my top turbo is a 62/12 d-tech turbo from diesel power source. how much horsepower can my twins set up hold. the botton is an ht3b.
Old Dec 11, 2008 | 02:42 AM
2500HeavyDuty's Avatar
what other mods done to it?
Old Dec 11, 2008 | 02:50 AM
SPEAKSUP's Avatar
Are you running an external wastegate on you HT3B?
Old Dec 11, 2008 | 01:24 PM
Diesel Nut's Avatar
Yeah, more info needed.
Off the top of my head I would say 600ish, but I could be off on that.
Old Dec 11, 2008 | 02:01 PM
Alli_Gator's Avatar
Site Sponsor - Alligator Performance
My brother has the same twins on his 07 Mega and he is around 600 with a diablo sport on RKL, 90 horse sticks, head studs, and stock fuel system. (we've now added a Raptor 150) We have yet to see it on the dyno since the lift pump. Hope you have better luck with those twins then he has...
Old Dec 11, 2008 | 11:32 PM
baseball31's Avatar
yes the bottom ht3b is waste gated. and what do you mean i hope u have better luck with those twins than your cousin? do i need head studs. and i have 75 hp nozzles and the stage 2 cp3 pump. with the edge juice stack with the triple dog downloader. .
Old Dec 14, 2008 | 10:52 PM
johnnymotown421's Avatar
head studs recommended!! yeah what do you mean better that your cousion?? Should we avoid that kit or something?
Old Dec 19, 2008 | 07:15 PM
baseball31's Avatar
i put the twins on and now my top end performance got worse. i dont know what is goin on. i mean i have plenty of fueling for it. i used to boost about 50 psi on the top end with my single that i had on there. it would throw you back in the seat too. now, with the twins once my over drive kicks in, the truck just fall on its face. i dont know whats goin on.
Old Dec 19, 2008 | 07:30 PM
SPEAKSUP's Avatar
Yeah Im with the rest of them I wouldn't be pushing it without headstuds. Theres so many variables when tunning Twins. Do you have a Crazzy Larry or Pedophile Larry Tune? Whats your EGTS? What kind of Convertor are you running are you on a stock Trans also?
Old Dec 25, 2008 | 02:20 AM
baseball31's Avatar
no crazy larry, just regular. my egt's are around 1250 to 1300, thats about it. i have a full goerend tranny. billet shafts and converters
