codes
Old Dec 7, 2008 | 05:08 PM
94cummins12v's Avatar
Default codes
is there a way to check for codes on a 2nd gen 94 cummins 12v? i dont have the little port under the dash like the 96's do. the reason im asking is the check engine light came on today. i dont know if i should be worried about it since almost half the engine isnt stock anyway (new head, turbo, injector pump, all the performance you can think of) or should i just pull the fuse?
Old Dec 7, 2008 | 07:21 PM
lilfroger's Avatar
I know the 3 key trick works on 2nd Gen 24v's ... not sure about 12v's though. But hey it's worth a shot right.
Turn the key from off to on 3 times without starting the truck. If it works you'll get a code or DONE on the ODO. If you get neither take the key out and start over. It normally takes me a time or two to get it.
Old Dec 7, 2008 | 09:18 PM
thats what i love about 12vs theres nothing that tells you what to do, we have the old style guages were nothing is digital meaning the roller type odometer
Old Dec 7, 2008 | 09:39 PM
stkdram55's Avatar
it should have atleast an OBD I on that truck, there has to be some way to read codes on it unless you might need to call a cummins dealer and ask what ya need to do.
Old Dec 7, 2008 | 09:41 PM
i might do that in the AM hours tomarrow just to see but im sure that its just because the hole upper half of the engine is new
Old Dec 8, 2008 | 12:18 AM
There should be a way to get the codes...I thought the key on/off thing worked, much like the 24Vs or you still should be able to use a scanner (I know you can on the later 12V's)
Old Dec 8, 2008 | 11:04 AM
ya i dont have the port under the dash like the 95-98 12vs and i dont have a digital readout on my dash like the 98-02 ramns do
Old Dec 8, 2008 | 11:34 AM
If the truck is running good I dont think Id be too worried.
Old Dec 8, 2008 | 12:36 PM
lilfroger's Avatar
Think I found it.
The 3 key trick does work...but it doesn't give you a digital code like the 24v's...it blinks at you. You've got to count the CEL blinks.
Cycle the key on and off three times. Leave it on the third time. Count the number of flashes the check engine light gives you. These will be the error codes. It will be a series of flashes with a small pause between numbers. If memory serves me right 12 is the start test code and 55 is the end code. We need the numbers in between.
Old Dec 8, 2008 | 08:35 PM
Originally Posted by lilfroger
Think I found it.
do what
