Diesel Dawgs Performance Visit - Diesel Dawgs Performance
Ford 6.0L Quadzilla Adrenalines Now Shipping
Old Dec 5, 2008 | 09:13 AM
FormerVendor
Default Ford 6.0L Quadzilla Adrenalines Now Shipping
Quadzilla is excited to announce the official release of the Ford Adrenaline!
180 RWHP Gain
325 Ft-lbs of Torque Gain
6 On-the-Fly Power Levels
Max Mileage Tuning level
Complete set of gauges - 20 + parameters
Built-in Guardian De-fueling EGT, Boost, Transmission and More
User defined shifting protection
Turbo Timer
Read and Erase DTC's
Failsafe Technology
Rugged Weatherproof Enclosure
USB Updatable
Best Towing Performance Available
Unparalled Throttle Response
0-60 mph Tests
1/4 Mile Performance Test
Introducing the most powerful, most feature rich, easiest to install, and most user adjustable on-the-fly engine management system ever produced for the 6L Ford. The Adrenaline module is packed full of usable and useful features unlike other products on the market.
The heart of the Adrenaline uses proprietary software unlike any other on the market allowing us to control the entire engine via the engines control bus. Our Failsafe technology means that under NO circumstance will you ever have any truck reliability issues even if the worst case scenario presents itself!
The Adrenaline utilizes its 100% control over injector pulse width, injection timing and injection control pressure to increase efficiency and add more power. This is a unique combination that before now was only available by buying multiple products and using them together.
The Adrenaline/Pulse is much more than a power adder or fuel mileage enhancement unit. With the Pulse you have access to over 20 parameters to monitor, record, and set alarms for. You also may set de-fueling settings for most of the monitored parameters. The Adrenaline does not simply cut fuel, but matches the fueling and timing curves to maximize power output while keeping exhaust temperatures below your preset level. Simply put, it is by far the safest and smoothest engine protection system on the market.
On your Pulse monitor there is a host of features that you will love. In addition to all the gauges, you have the ability to adjust your Turbo Timer, set cold engine protection parameters, adjust fueling during shifting, test 0-60 MPH and ¼ mile times, and recall your minimum and maximum achieved parameters.
If you need more you may choose to purchase an unlock code that allows you to custom tune your Adrenaline on-the-fly via the Pulse monitor. With this feature unlocked you will be able to set maximum pulse width, maximum timing advance, maximum injection pressure, decide when to add fuel and control the pedal feel of the power plus much more!
There is no other performance product on the market that can match the features, mileage gains and power gains of the Adrenaline module.
Parameters Monitored:
EGT
Load%
RPM
IAT
Fuel Level %
TPS%
MAF
Runtime
EGR Error%
Boost
Coolant Temperature
Speed
Corrected Speed
Voltage
Gear
Transmission Temp
EGR %
Barometer
Injection Control Pressure
Distance with MIL
# of Warm-ups since DTC Cleared
Mileage since DTC Cleared
$594.15 with Control Pod
$764.14 with Pulse
Don't forgot Quadzilla products are 15% off for Christmas
makuloco2000
Feb 15, 2015 02:31 PM
tbreddiesel
Thoroughbred Diesel
Jan 12, 2015 02:23 PM
Dec 10, 2014 08:10 AM
Oct 13, 2014 08:10 AM
