fuel pressure gauge problems
Old Dec 1, 2008 | 05:33 PM
jss549's Avatar
Default fuel pressure gauge problems
I have a 2001 dodge cummins, I have installed a electric fuel pressure gauge,and my sending unit did not come with an adapter to connect to my fuel line. My sending unit has 1/8 npt male threads, what do I need to connect it to my fuel line? I was told that a banjo bolt would connect but I just don't see how. Appreciate any info.
Old Dec 1, 2008 | 05:38 PM
cummins24's Avatar
Try re-posting this thread in the 2nd gen. 24 valve Cummins forum and I bet you'll get some responses a little quicker
Old Dec 2, 2008 | 01:26 AM
Youre setup should look a little something like this (this is on an 01 - but its an install for a mechanical guage):
You will need a tapped banjo bolt (for a 24V) - this is avaialble from any diesel performance shop. You will screw youre sender into the bottom of the banjo bolt, and instead of hose running into the cab, you will have wire. I would recommend installing a needle valve, like it shows in the picture. The needle valve should be open just a hair so it dampens the pulses from the VP-44. This will help save your sender from an early death.
I would have recommended running fuel into the cab - cheap, easy, and no problems.
Old Dec 2, 2008 | 11:34 AM
dukeboy_318's Avatar
X2
Old Dec 4, 2008 | 09:42 AM
Mopar1973Man's Avatar
X3
Like usual Dr.Evil is on top of his game!
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
