Grid heater ground?
Old Dec 1, 2008 | 12:53 AM
Cummins97's Avatar
Question Grid heater ground?
Where would I locate one of these little wires? For some reason mines gone. I've always wondered why they never worked. Could I just use a battery cable to make one or that to heavy gauge?
Old Dec 1, 2008 | 01:00 AM
Are you talking about the wires that run from the drivers side battery??
Old Dec 1, 2008 | 01:07 AM
Cummins97's Avatar
"I think" it hooks to the bottom nut on the back of the heater and to the intake horn bolt.
Old Dec 1, 2008 | 01:58 AM
Ok, I thought you were talking about the 2 fusible links that go from the drivers side battery to the relays on the fenderwell.
Old Dec 1, 2008 | 02:03 AM
Cummins97's Avatar
This wire.....
Old Dec 1, 2008 | 07:09 AM
wildbill's Avatar
That's the + supply. The grid heater grounds through the 4 bolts and the manifold. The gaskets are metallic with a metallic coating for a better ground.
Old Dec 1, 2008 | 02:07 PM
Cummins97's Avatar
So this wire does hook to the intake horn right? and the heater wont work with out it right?
Sorry not much on the electrical stuff...
Old Dec 1, 2008 | 08:30 PM
wildbill's Avatar
It runs to a relay either on the drivers side or passenger side. Be two small wires on top and a cable coming off the battery to a large post.
Old Dec 2, 2008 | 01:11 AM
Cummins97's Avatar
You lost me.
I'm talking about the approx. 5" long wire thats shown in the pic hooked to the back of the heater. It hooks to the intake horn. Right?
dodge2014
Apr 16, 2015 08:54 PM
95 cummin
Jan 21, 2015 11:54 AM
Rooster24v
15
Jan 4, 2015 08:20 PM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
justinsbeck
Nov 22, 2014 03:03 AM
