3k GSK install
Old Nov 30, 2008 | 09:25 PM
usmcbay's Avatar
Default 3k GSK install
Okay - I have a couple of questions.
I JUST found my 3k GSK in my Garage after throwing it to the side for over a year... I am going to order some 60lb VS's. Here is my question:
I ordered these from City Diesel... can I buy the $15.99 4k upgrade springs and be sure that they will work with these 3k's?
I noticed PureDieselPower, CumminsDieselPower, PureCummins, etc. all offer this and it all seems to be the same. All Inner Springs offered seem to be made by Bosch from those that list that... For $16 it seems to be worth the risk.
Is the 3k a notible difference? And would this be the time to adjust the AFC bar?
Old Nov 30, 2008 | 09:55 PM
94cummins12v's Avatar
i went all out and got the 4k you dont have to have hd springs as long as you dont excede 3200RPM if you do you should replace them i got a used set (150 miles) here if your interested
Old Nov 30, 2008 | 10:46 PM
usmcbay's Avatar
I tried to send you a PM but I only had 9 posts and must have 10 to PM...
So... this is Number 10. Ha!
Now that I installed my #10 I'm thinking about grinding my #11 to something... any suggestions.
Also I have started to have Fuel Shut-Off Solenoid problems... but I steamed my engine the same night I installed the #10 so not sure if it is my Arm that somehow has made my FSOS work only occasionally - now almost never. Well - it has to be pulled up to start but shuts down fine. One unique thing is if I pump my peddle to get it started instead of popping the hood and pulling it up... my power is dead flat if I pump the peddle to start... That makes me think my arm is not hitting right without monkey-ing with the FSOS.
Any suggestions on that?
Old Nov 30, 2008 | 10:54 PM
i remember doing that last year
Old Nov 30, 2008 | 10:57 PM
usmcbay's Avatar
Old Nov 30, 2008 | 11:00 PM
with your fuel shutdown issue my budys 95 did that this summer check all the bolts that hold down the AFC and that hold the selinoid to the bracket that mounts to the ACF his was really loose
Old Dec 3, 2008 | 09:55 PM
jasonw's Avatar
The 3k springs will make a noticeable difference over the stock ones in there now. And yes, the only difference between the 3k and 4k springs is the small middle one.
Old Dec 4, 2008 | 08:59 PM
usmcbay's Avatar
Yes it did make a difference. I put a straight PTO cable to my fuel shutoff and realized I had some funny business with my solenoid that was only supplying half of what I needed. Now I have a 5 speed rocket!
My 4k upgrade will be going in hopefully this weekend. Then I have to get serious about the Death Wobble and stop worrying about G-Forces.
Old Dec 5, 2008 | 09:24 AM
jasonw's Avatar
Seems like I had that problem. The solenoid was only coming halfway up and causing some problems. Glad to hear it's working good. I love GSKs.
JoeyMiR
9
Feb 3, 2018 10:05 PM
David Burger
Aug 11, 2015 06:22 PM
Gman30
Dec 27, 2014 12:46 PM
Cody Cain
Dec 22, 2014 01:27 PM
JustAnother_cummins_guy
Nov 10, 2014 09:44 PM
