7.3 help running
Old Nov 26, 2008 | 06:52 PM
justuc's Avatar
Default 7.3 help running
i have a 94 7.3 turbo diesel and i can get it running and drive it for bout 5 min and the fuel filter light comes on and runs like crap! if i give it gas and then let it go back to idle it will die. while running i can spray all lines with brake clean and it does not rev up none. im a dodge man and cant figure it out> any help is appreciated
Old Nov 26, 2008 | 08:16 PM
Hummin Cummins's Avatar
Is this a 7.3 IDI engine?
Old Nov 26, 2008 | 09:35 PM
justuc's Avatar
it has the manual fuel pump on side of the motor
Old Nov 27, 2008 | 07:21 AM
I assume you changed the fuel filter.
I have seen where the injection pump is getting weak it can run when it (The injection Pump ) is cold but as soon as it warms up internaly it can't produce enough pressure.
When my 6.9 did this I just took the pump off and had it rebuilt. I have been told by more then one person if you poor cold water over the pump you can get the truck to fire back up. That may be a option to help trouble shoot your problum. But like I said I was told this and never tried it so you might want to get a few other opinions from others before trying it.
What do you have to do to get the truck to start again?
Old Nov 27, 2008 | 08:55 AM
Diesel Decals's Avatar
Yeah Id go for the filter and then the pump. If you dont wanna get it rebuilt and want a cheap test pull one out of a junkyard. There usually pretty cheap and try it. That way you can run the truck while the other one is being rebuilt
Powerstroke36
Sep 29, 2015 07:16 PM
Msc
Apr 23, 2015 06:21 PM
carid
Diesel Bombers Sponsors
Apr 6, 2015 08:43 AM
1997fordf350
Jan 15, 2015 06:12 PM
carid
Jan 12, 2015 04:32 AM
