fuse question
Old Nov 25, 2008 | 08:44 PM
dalton06's Avatar
Default fuse question
What side of the fuse it the dead side? Is there a positive and negative on each end of prongs, or on each side of fuse? I just need to plug my outlook fuse tap into the dead side of the fuse. Just trying to get the pos to work right.
Old Nov 25, 2008 | 09:05 PM
Hummin Cummins's Avatar
Thier is no negative, both sides are positive. If you hook the fuse tap to the dead side if the fuse blows your outlook will go out.
I don't remember which side is the dead side if you have a test light pull the fuse out and that will tell you.
Old Nov 25, 2008 | 11:01 PM
stkdram55's Avatar
just get a test light and check the fuse that they tell ya to put it on, pull the fuse and turn the key on and touch the two sides of the fuse box prongs and there ya go see which one is hot and not
stone9291
Jul 23, 2015 05:13 PM
david.burger
May 30, 2015 08:25 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
Altonlee
Oct 1, 2014 04:58 PM
