12 Valve help
Old Nov 25, 2008 | 07:42 PM
00stroker's Avatar
Default 12 Valve help
What is the best transmisson to use on my 94-98 12valve cummins. And is there differnt types of turbos that came with the 12 valve becuase i got my motor out off a old bus and didnt know if it was the same as the 12 valve in the 2500 or 3500
Old Nov 25, 2008 | 08:34 PM
94cummins12v's Avatar
NV4500 tranny and hx35/40 hybrid for a stocker type turbo
Old Nov 25, 2008 | 08:37 PM
Racer9's Avatar
Different applications had their own stats. It might be the same as 25/3500, just check the tag on the turbo. It might say HX35, which is what the p/u's have.
As far as trans, what are you planning to do with it? Daily driver with no power upgrades, an auto will be fine.
All out puller, you'd be better off with a standard.
Like to shift, go manual, don't like to, go auto.
Autos can be upgraded to handle more power but $$.
Old Nov 25, 2008 | 09:18 PM
00stroker's Avatar
I want to make a puller with it so i want a manual what type of manual trans would be the best for the $$. could get an adapter for a non dodge trans but know what kind that would be.
Old Nov 25, 2008 | 10:56 PM
stkdram55's Avatar
nah ya really dont need to go with a different maker of tranny, the NV4500 would be your best bet, just get a good clutch and the bigger input shaft and pull away the tranny should be fine til like 5-600 ponies
Old Nov 25, 2008 | 11:22 PM
xzaq103's Avatar
FormerVendor
I would go with a nv4500 and the linkage and shifter out of the 98-02 and add a bd short shifter. through a south bend dual disk in. As for turbo for pulling. Are you going to run single or twins? I would say a sled puller 66 and ddp4s should put you there with some pump tweaking and maybe 191s
Old Nov 25, 2008 | 11:30 PM
i though you couldnt put a short shift kit in a nv4500 i cant find a place that sells them for the 5 speed
Old Nov 26, 2008 | 12:35 AM
Right here: BD Power - Product: Short Shift Kits
Old Nov 26, 2008 | 12:41 AM
ya but that only says 1998 and up nv4500's not a 94
Old Nov 26, 2008 | 01:16 AM
stkdram55's Avatar
thats why he said to go with the linkage from a 98-02 model even though im not sure that is possible, the top plate on the transmissions are different from 94-98 12v's there kinda of at an angle where as on the later models its more straight across and it makes it easier to pull the tranny since you can reach thru the floor and take everything off and drop the trans straight down instead of having to turn it a little to get the earlier models out
