P-O483 CODE ANYONE ELSE HAVE THIS HAPPEN
Old Nov 25, 2008 | 02:18 PM
STROKER400's Avatar
Default P-O483 CODE ANYONE ELSE HAVE THIS HAPPEN
I cycled my key 3 times to see if there where any codes and this code shows up.. I called the dealership and they said its a fan speed code. But I never had a light come on. Wouldnt a light come on for this?
Old Dec 16, 2008 | 06:39 AM
I6_or_die's Avatar
FormerVendor
A LIGHT SHOULD COME ON FOR ANY CODE NO MATTER HOW SMALL OF PROBLEM!!
Old Dec 16, 2008 | 08:11 AM
wildbill's Avatar
Either a faulty clutch fan, faulty or shorted harness, faulty ECM, or it's an intermittent problem. I'd say there is a short cause the light was on at one point, but the problem corrected itself, and with a few good key cycles, the light shut off. But the code remains in the ECM for diagnostic reasons.
Old Dec 16, 2008 | 08:12 AM
wildbill's Avatar
If it comes back on, disconnect the plug and clean the connection. Also find out if the wires were rubbing anywhere and fix as necessary.
dwmeehan
Sep 6, 2015 04:20 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Oleoleson
Chevy/GMC Duramax 01-04 LB7
Mar 28, 2015 06:20 PM
Backhoeman
Jan 3, 2015 12:53 PM
