Group Buy Group Buys And Discussions of Group Buys On All Diesel Related Products
Performax gauge
Old Nov 24, 2008 | 06:13 AM
HOLYSMOKES's Avatar
NADM Member
Default Performax gauge
We are going to do a group buy on the Performax gauge line. This will be a little different than other buys. Instead of one set product, we are going to let you pick what you want. The only thing to go by is that you must buy the ESP, and two gauges. You can do as many as you would like. You can run 17 gauges with one ESP. We need a total of 10 people for the group prices. PM for me for pricing. Thank you. Smokes
Greg Gall
New Era Diesel
Outside Sales
Here is a list of some of the guages offered. There are more at their web site.
R82021 Pyrometer 0-1600° F
R82031 Pyrometer 0-2000° F
R82599 Transmission Oil Temp 100-280° F
R82566 Transmission Oil Temp 140-320° F
R82133 Turbo Boost 0-30 PSI
R82333 Turbo Boost 0-40 PSI
R82233 Turbo Boost 0-60 PSI
R82433 Turbo Boost 0-100 PSI
R82055 Fuel Pressure 0-40 PSI
R82077 Fuel Pressure 0-60 PSI
R82044 Fuel Pressure 0-100 PSI
R82588 Coolant Temp 100-280° F
R82577 Coolant Temp 140-320° F
R82211 Oil Pressure 0-100 PSI
R82533 Oil Temp 100-280° F
R82544 Oil Temp 140-320° F
R82100 Exhaust Backpressure 0-40 PSI
R82122 Exhaust Backpressure 0-60 PSI
R82155 Exhaust Backpressure 0-100 PSI
R82511 Rear Axle Temp 100-280° F
R82600 Voltmeter 8-16 VDC
R82092 Pyrometer #2 0-1600° F
R82022 Pyrometer No-Color 0-1600° F
R82032 Pyrometer No-Color 0-2000° F
R82091 Pyrometer #2 No-Color 0-1600° F
R82244 Trans Pressure 0-180 PSI
R82522 Front Axle Temp #2 100-280° F
R82255 HPOP Pressure 0-4000 PSI
R82222 Air Temp 0-240° F
R82377 Turbo Boost #2 0-40 PSI
R82277 Turbo Boost #2 0-60 PSI
R82477 Turbo Boost #2 0-100 PSI
R82266 Air Pressure 0-180 PSI
R82288 Fuel Rail Pressure 0-30k PSI
R82900 Fuel Level E-F 240-33 Ohm
R82088 Drive Oil Pressure 0-400 PSI
It will run till Dec 8th
Last edited by HOLYSMOKES; Nov 24, 2008 at 06:13 AM. Reason: Automerged Doublepost
Old Nov 25, 2008 | 06:15 AM
DB Admin's Avatar
Banned
Thanks GReg
Old Nov 26, 2008 | 03:58 PM
HOLYSMOKES's Avatar
NADM Member
here is a little more information on them
http://www.isspro.com/performax_presentation.pps
Old Nov 28, 2008 | 01:40 PM
Desperado's Avatar
Messed up I was looking at the white pointers and need the red.
Old Nov 28, 2008 | 02:29 PM
Dirt Tracker's Avatar
deleted this message because saw I should PM for pricing.
Old Nov 28, 2008 | 09:52 PM
HOLYSMOKES's Avatar
NADM Member
Dirt Tracker you have mail!
Desperado, I noticed you had a second gen truck, the red pointer matched the second gen. I quoted you the black face with red pointer and white numbers. If you want different ones it's no problem at all!
Old Nov 29, 2008 | 09:17 PM
Desperado's Avatar
That is what I was looking for, dose the pyro, have the rianbow face with red pointer?
Old Nov 30, 2008 | 07:55 AM
HOLYSMOKES's Avatar
NADM Member
The one I quoted you does. They also have one without.
The one without the color looks to run aprox. $5 more
Last edited by HOLYSMOKES; Nov 30, 2008 at 07:55 AM. Reason: Automerged Doublepost
Old Dec 3, 2008 | 06:31 AM
HOLYSMOKES's Avatar
NADM Member
4 more days
Old Dec 3, 2008 | 08:37 PM
Desperado's Avatar
New pm sent. Thanks
