Price Quote - Request A Price This Forum is for Requesting Price Quotes - Upon Your New thread All Participating Vendors & Distributors Will Receive a Private Message Notifying them Of your Thread - You May Opt Out of this Option
Boost pipe from turbo to intercooler
Old Nov 22, 2008 | 08:54 PM
Nitelord's Avatar
Default Boost pipe from turbo to intercooler
(see signature for year, make and model.)
The tube running from the turbo to the intercooler appears to be too short. The boots appear to be too short to allow for the engine movement under heavy torque. Over the past 3 months, two boots have come loose. One from the turbo, the other from the intercooler. Is there a manufacturer that you would recommend that makes a tube that removes the rubber boots or is designed to handle the engine movement to a greater degree than the stock parts?
Thanks in advance, Mark
Old Nov 22, 2008 | 10:27 PM
94cummins12v's Avatar
most dealers has replacement boots with clamps
Old Nov 22, 2008 | 10:33 PM
DB Admin's Avatar
Banned
MArk Make sure you get the Spring Clamps with them , they compensate for the swelling under big boost and keep the boots from sliding off , Use Hair Spray when you put them on so they slide on ez and wont come off as well
Old Nov 22, 2008 | 11:09 PM
Nitelord's Avatar
Thanks for the tip DM. I'll make a note of that.
I'm really not interested in OEM parts. I'm hoping for something a whole lot stronger and made to take abuse. Thanks..
Old Nov 22, 2008 | 11:12 PM
thats what they are there blue with spring clams rated for like 75PSI of boost i belive i getting a set from high desert ravelco this winter, almost every company on here has them
Old Nov 22, 2008 | 11:22 PM
Nitelord's Avatar
Cool. Hopefully they will respond to the mass PM.
Old Nov 22, 2008 | 11:38 PM
should get something
Old Nov 23, 2008 | 02:13 PM
cbrahs's Avatar
pm sent Mark
Old Nov 24, 2008 | 09:24 PM
Nitelord's Avatar
All taken care of. Thanks much Chris.
Old Nov 24, 2008 | 09:47 PM
cbrahs's Avatar
glad to help Mark.
avatardvr
18
Aug 8, 2019 12:38 AM
timmyd
Jun 8, 2015 11:35 PM
n2brk
Feb 21, 2015 09:05 AM
ash23k
Dec 30, 2014 08:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
