Boost tube from Turbo to Intercooler.
Old Nov 22, 2008 | 08:24 PM
Nitelord's Avatar
Default Boost tube from Turbo to Intercooler.
I have a quick question. The tube running from the turbo to the intercooler appears to be too short. About 3 months ago it separated from the turbo (at the first rubber boot). I reconnected it and really torqued the clamp down.
Last night it separated from the intercooler. (with a loud POP!) Fixed again.
My question is that it appears to be too short to allow for the engine movement under heavy torque. Is there a manufacturer that you would recommend that makes a tube that removes the rubber boots or is designed to handle the engine movement to a greater degree than the stock parts?
Thanks for your help, Mark
Old Nov 22, 2008 | 08:27 PM
DB Admin's Avatar
Banned
Mr. Bobs is an option
Old Nov 22, 2008 | 08:35 PM
Nitelord's Avatar
Wow, That is blue.
Have you used them? It seems like a pretty complete kit.
Old Nov 22, 2008 | 08:36 PM
Whit's Avatar
Site Mascot
the OEM boots are very weak.............you need some aft mkt boots, the 2 you are talking bout are most suseptable
Old Nov 22, 2008 | 08:38 PM
DB Admin's Avatar
Banned
Old Nov 22, 2008 | 08:45 PM
Nitelord's Avatar
Ok DM. I see you have used them. Any problems since the install?
$519 is a lot of cash, but it is a complete kit.
Kevin, I found out the hard way. The first time I didn't know if I was going to make it home. The truck ran like crap and the EGT's went through the roof getting up my driveway.
I definitely need a fix.
I'll see about getting Mr Bob's on Monday. Thanks much.
Anyone else found a different manufacturer I should look at?
Old Nov 22, 2008 | 08:47 PM
Whit's Avatar
Site Mascot
do a request from our vendors and you may be suprised
Old Nov 22, 2008 | 08:49 PM
DB Admin's Avatar
Banned
BD makes a kit and a few others , the MR.Bobs is all the coolent hoses and ect you really dont need all that just the boost boots and spring clamps
Old Nov 22, 2008 | 08:57 PM
Nitelord's Avatar
I put a quote request out.
I don't mind doing all the pipes. It's probably not a bad idea.
However, with Christmas just around the corner, I'm thinking I should keep the spending to a minimum. (at least on things for me.)
sak240
Oct 1, 2015 04:07 PM
rodbuilder
Jun 26, 2015 12:48 AM
n2brk
Feb 21, 2015 09:05 AM
offroad00
24
Oct 23, 2014 03:28 PM
GreenDieselF
Oct 20, 2014 02:05 PM
