pull cable for fuel shut off
Old Nov 21, 2008 | 07:04 AM
dieseldick's Avatar
Default pull cable for fuel shut off
i purchased a parker P.T.O. cable and am in the process of installing. any tips or tricks.
should put a spring with tension to shut off. this cable doesnt lock it s just the tension type.
i thought the nice locking one would be worn out in half of year because of the constant use.
any suggestions.
Old Nov 21, 2008 | 03:59 PM
dodgeman129's Avatar
i got a cable shut off on mine but when im driving sometime it pulls itself back in and shuts the truck off i dont like it im going to put the shut off solenoid back on it
Old Nov 30, 2008 | 09:37 PM
usmcbay's Avatar
I ran a cable on my '94 from the shut off "lever" through the firewall and then through the seam of the two portions of the dash - still had to drill a hole in the dash. It was just plain cable - like clothes line cable and I put a spring to keep it in the ON position and just pulled the cable to kill it. I would have rather had a PTO cable but hey... I did it on an emergency basis and just never fixed it. Sold the truck that way too. It was REALLY easy.
Old Nov 30, 2008 | 09:44 PM
Cummins97's Avatar
I did the same thing. Temp fix till I got another solenoid.
Making a bracket was the fun part.
Old Dec 1, 2008 | 01:59 AM
SixOhh's Avatar
that's fine. the type of cable isn't the big deal to me, it's the spring backing it up.
any parts house has "throttle return springs" in the help section. get you a stiff spring for the shutoff so you know it wont shut off on you when u least expect it.
Old Dec 1, 2008 | 08:25 PM
gone ropin's Avatar
an ol boy is currently parting out a 96 ctd on ebay hes got a working solinoid on ebay preaty cheap ol boy is out of paris arkansaws
Old Dec 2, 2008 | 03:00 PM
SixOhh's Avatar
i still dont think they last from what ive read.
Old Dec 2, 2008 | 08:49 PM
Racer9's Avatar
What don't last? The solenoid is very simple and reliable. As far as I know mine is the original one with 120k on it. It's the relays, that sometimes go, but more often it's the (blue?) wire from the battery that goes bad. Usually MIS-diagnosed as a bad solenoid.
Old Dec 2, 2008 | 11:33 PM
SixOhh's Avatar
well that's good to know
Old Dec 3, 2008 | 01:12 PM
MotorOilMcCall's Avatar
I have a PTO cable on my truck for a shut-off, and no complaints ever! No need for a spring, there isn't any tension on the cable to pull it to the "Off" position. Push in is on, pull out is off, works like a charm.
camp9
Mar 25, 2017 07:40 AM
Hollie
6.2L & 6.5L Performance
Jan 14, 2016 01:32 PM
bubba_pa
Diesel Related Events
May 15, 2015 11:52 PM
james2562
Nov 2, 2014 08:31 AM
T Mack
Oct 19, 2014 11:39 PM
