Stock 12 Valve going for 400-500hp. Any suggestions?
Old Nov 20, 2008 | 10:43 AM
HelenaTDI's Avatar
Bomb Stock 12 Valve going for 400-500hp. Any suggestions?
Newbie to the site. My P.O.S. stock tranny took a dump on me a couple of weeks ago. New Goerend is on the way. Now that I have a real trans coming I want to turn up the truck. The truck has been completely bone stock all it's life and has been pretty boring to drive. Time to bomb the rig.
This is along the lines of what I had planned:
1. Gauges (boost, pyro, trans) top priority.
2. Exhaust MBRP 5"
3. AFE Stage II
4. 4K GSK
5. AFC Spring Kit
6. Fuel plate "0"
7. BD-Super "B" Single (clueless really on what turbo would be best, I need help on that)
8. Boost elbow
9. DDP 75hp injectors
10.Timing advanced to 16.5?
Did I miss anything? Will the above get me in the 400-500hp range and what torque?
Thanks for the input.
Old Nov 20, 2008 | 10:51 AM
ltr450's Avatar
don't forget about different dvalves, airdog fuel system, different head studs stock head is rated at 55psi. 60lb valve springs. as for turbo go with and hx.
Old Nov 20, 2008 | 11:06 AM
HelenaTDI's Avatar
Oooof! Yeah a few more items I missed. What HX model #?
Old Nov 20, 2008 | 11:30 AM
I think your going to need more fuel than those parts are going to get you and a HX isnt going to get you to 500 hp. Youre going to need:
- Bigger delivery valves
- DDP 4's
- Turbo choices are huge - not sure ID go with a BD Special. HTT and Industrial Injection have some very nice turbos.
You do not need an Airdog on a 12V - The OEM fuel system will easily support 650 hp.
Old Nov 20, 2008 | 01:22 PM
HelenaTDI's Avatar
Checked out the HTT and Industrial turbos. Very nice. DDP 4's are 140HP injectors?
Old Nov 20, 2008 | 01:31 PM
Yes DDP4's 140 hp.
You might also want to look at the New Era 435's or F1 injectors as well.
Old Nov 20, 2008 | 01:56 PM
xzaq103's Avatar
FormerVendor
Im in the same place you are just a few steps ahead right now im trying to decided if i want to go with new era 370s, 435s or dd3s or 4s Im planning on running a sps62, ps62 or HTB2 or super stock 62. and detune the pump if i go with the 435s or ddp4s
Old Nov 20, 2008 | 06:32 PM
89silverbullet's Avatar
f1 injectors are rowdy strong injectors.
Old Nov 20, 2008 | 09:12 PM
HelenaTDI's Avatar
So F1 outperforms anything DDP has then?
Old Jan 4, 2009 | 12:37 PM
12valvetater's Avatar
Get a shop to make some 5-.013 injectors. Compound turbos are the way to go. I'm shooting for about the same output and my plans are to use my hx-35 with an s400. Cant forget studs, and 60lb valve springs.
