New Era Diesel Visit - New Era Diesel
Isso Pro Perfor-Max Guages
Old Nov 20, 2008 | 06:55 AM
HOLYSMOKES's Avatar
NADM Member
Default Isso Pro Perfor-Max Guages
We will be starting a special group buy on these starting this weekend. You buy the module and at least 3 guages to get the special pricing. You can run up to 17 guages on the module. The module mounts under the hood and you bring 3 wires into the cab...reguardless of how many guages you gring inside. I will post more info as it comes. Pm me for pricing.
Look for our install guide in an upcomming Diesel World Magizine issue! Once its released, there is a good chance the group buy is over and will go back up to standard price.
Old Nov 20, 2008 | 07:17 AM
RSWORDS's Avatar
hhhmmmmmmm
Old Nov 20, 2008 | 07:20 AM
stkdram55's Avatar
I talked to him at a pull a few months back, these things are sweet...you can run something like 17 guages right off this pod, but you only have run a coulple wires thru into the cab. But you only have to hook up the thing underneath the hood...Its crazy and there might be a little more to it but thats the general jist of it...
Old Nov 20, 2008 | 02:55 PM
HOLYSMOKES's Avatar
NADM Member
Well, and the moonshine still that goes under the hood too. LOL (when you see the pic you will understand.....)
Old Nov 22, 2008 | 07:30 PM
HOLYSMOKES's Avatar
NADM Member
We are going to do a group buy on the Performax gauge line. This will be a little different than other buys. Instead of one set product, we are going to let you pick what you want. The only thing to go by is that you must buy the ESP, and two gauges. You can do as many as you would like. You can run 17 gauges with one ESP. We need a total of 10 people for the group prices. PM for me for pricing. Thank you. Smokes
Greg Gall
New Era Diesel
Outside Sales
Old Nov 22, 2008 | 07:55 PM
DB Admin's Avatar
Banned
Thanks for this opportunity Mr. Gall
Old Nov 22, 2008 | 10:02 PM
woodsrat's Avatar
A little more on this setup. As stated you can run 17 gauges with one ESP. They have a total recall feature. Just push a button and recall all the highs and lows of the gauges. There is also a data logger option so you can plug your laptop in and store all info from inside the cab. All wiring stays under the hood and you daisy chain the gauges together. No more splicing and making harnesses. The gauges clip onto the three wires and you can move them at will.
Chuck
Old Nov 23, 2008 | 09:12 AM
HOLYSMOKES's Avatar
NADM Member
To give you an idea of what guages you can run. Also bear in mind no matter if you run 2 guages or 17, only 3 wires go into the cab. They are all electric so no tubing, isolator ect running in the cab either.
R82021 Pyrometer 0-1600° F
R82031 Pyrometer 0-2000° F
R82599 Transmission Oil Temp 100-280° F
R82566 Transmission Oil Temp 140-320° F
R82133 Turbo Boost 0-30 PSI
R82333 Turbo Boost 0-40 PSI
R82233 Turbo Boost 0-60 PSI
R82433 Turbo Boost 0-100 PSI
R82055 Fuel Pressure 0-40 PSI
R82077 Fuel Pressure 0-60 PSI
R82044 Fuel Pressure 0-100 PSI
R82588 Coolant Temp 100-280° F
R82577 Coolant Temp 140-320° F
R82211 Oil Pressure 0-100 PSI
R82533 Oil Temp 100-280° F
R82544 Oil Temp 140-320° F
R82100 Exhaust Backpressure 0-40 PSI
R82122 Exhaust Backpressure 0-60 PSI
R82155 Exhaust Backpressure 0-100 PSI
R82511 Rear Axle Temp 100-280° F
R82600 Voltmeter 8-16 VDC
R82092 Pyrometer #2 0-1600° F
R82022 Pyrometer No-Color 0-1600° F
R82032 Pyrometer No-Color 0-2000° F
R82091 Pyrometer #2 No-Color 0-1600° F
R82244 Trans Pressure 0-180 PSI
R82522 Front Axle Temp #2 100-280° F
R82255 HPOP Pressure 0-4000 PSI
R82222 Air Temp 0-240° F
R82377 Turbo Boost #2 0-40 PSI
R82277 Turbo Boost #2 0-60 PSI
R82477 Turbo Boost #2 0-100 PSI
R82266 Air Pressure 0-180 PSI
R82288 Fuel Rail Pressure 0-30k PSI
R82900 Fuel Level E-F 240-33 Ohm
R82088 Drive Oil Pressure 0-400 PSI
If you see a part number pm it to me. We will get you special pricing at that point.
Last edited by HOLYSMOKES; Nov 23, 2008 at 09:12 AM. Reason: Automerged Doublepost
Old Nov 23, 2008 | 06:02 PM
woodsrat's Avatar
This buy will run till Dec.8th.
Old Nov 24, 2008 | 05:17 PM
HOLYSMOKES's Avatar
NADM Member
Keep them rolling guys!
