Ignition Problems
Old Nov 18, 2008 | 09:46 PM
Uncle Bubba's Avatar
Default Ignition Problems
My trucks givin me fits tryin to start it once in a while and I need to get somethin done with it before I'm stuck someplace. For quit a while now I've had key problems. Sometimes the key locks up and won't turn to start the truck. I can keep wigglin it around or turn it over and it will usually work just fine. So I know right of the bat I have a problem there I need to fix.
Tonight it started not startin when I turn the key. I can hear the selenoid click but nothin after that. I just kept doin it and eventually it caught and fired up. When it catches it fires right up, no problem there. Somethin electrical isn't makin connection here.
So is it the ignition wire bad, bad starter contacts, clutch safety switch maybe, give me some ideas.
Also since I know I need to change the ignition switch any how to's on that would be nice.
Old Nov 18, 2008 | 10:03 PM
Benjamin's Avatar
Bombardier
i'd say the starter is acting up when it "clicks"....... the key situation sounds like my powerstroke..... it came with 2 very used keys and i'd have to wiggle it, slide it flip it over etc..... went to ford and had them cut me a ket by the VIN and all is good now. works perfect, i made a copy of the new one and put it away for safe keeping.....
Old Nov 18, 2008 | 10:08 PM
stkdram55's Avatar
The key thing sucks becuase you have to go to the dealership and get the tumbler(switch) made to fit your key and for a Dodge Minivan getting this done cost like $150 bucks, and my starter did the same thing to me last spring, i just ended getting a reman from autozone been working ever since
Old Nov 19, 2008 | 08:20 AM
Mopar1973Man's Avatar
I went to NAPA and bough a replaccement key lock. Rather cheap and easy to replace. But Now my Mom's truck has 2 keys now 1 for the ignition and on for the doors.
Sound like starter contacts are going bad. You can rebuild that starter yourself for very little cost. Stop in your local parts store and get the contacts and brushes and do it yourself.
Starter need to be rebuild which you can do yourself. The key lock is bad in the column so that needs replacement.
Take the cover off the neck of the steering column. Your going to need a set of tamper proof torx bits for the removal of the last few screws. I got a small set of them from NAPA. Once you take the few screw out thge lock slides out... Not hard at all... I wish I could put more information but I can't remember exactly how it went... All I can say is its about a 15-30 minute job.
There you go my 2 cents on the subject...
Old Nov 19, 2008 | 08:28 AM
Whit's Avatar
Site Mascot
I agree....starter contacts
Old Nov 19, 2008 | 05:27 PM
DB Admin's Avatar
Banned
Starter Contacts ,
Foster's Truck & Equipment Sales, Inc.
Larry B's Starter Contacts
Old Nov 20, 2008 | 10:36 PM
Called Larry B's tonight and put my order in. Gettin the Starter Contacts, Starter Relay, and the oil drain from him. Hopefully this will fix it all up. Wish I'd seen this relay before now I would have had that installed a long time ago. Also gonna go ahead and change out the sensor that hides behind the starter while we have it out to.
LarryB's Dodge starting problems solved here.
Old Nov 20, 2008 | 10:39 PM
DB Admin's Avatar
Banned
TAKE PHOTOS
My trucks under Murphys Law
tom88k5
Jun 16, 2015 12:57 PM
david.burger
May 30, 2015 08:25 AM
Mar 13, 2015 09:20 AM
Zachbishop
Feb 10, 2015 10:23 AM
Tucker126
Jan 2, 2015 08:09 AM
