gear/axle ratio question
Old Nov 18, 2008 | 01:40 PM
dhardy1357's Avatar
Default gear/axle ratio question
i have the quadzilla stealth 2 on my 01 duramax. there is an adjustment you can make on the programmer about the gear/axle ratio. do i adjust this or leave it alone. also, my speedometer isnt corrected even when i set it for my 33" tires. anybody had this before or know what to do?-thanks
Old Nov 19, 2008 | 12:02 AM
2500HeavyDuty's Avatar
gear axle should be 3.73 leave it at that if it isnt already.
if you move on after that screen is should ask if you want to calibrate for bigger tires, then slect yes and change to the correct size.
Old Nov 19, 2008 | 01:38 AM
stkdram55's Avatar
Old Nov 19, 2008 | 08:24 AM
jdugie123's Avatar
ya don't touch the gear ratios unless you have changed them out the truck came with 3.73 from the factory
Josh_L
Apr 12, 2015 12:12 PM
99&91cummins
Mar 4, 2015 01:56 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
Down South
Jan 11, 2015 01:33 AM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
