Power Puck, Boost Fooler??
Old Nov 14, 2008 | 07:01 PM
thebreeze04's Avatar
Default Power Puck, Boost Fooler??
Sometimes it will throw a boost code and shut down (not going into limp mode) I have to remove the puck and fooler so it will run after I get the code to clear I can put them back on and it runs fine for awhile (over a month this last time) then it all happens again. Any suggestions?
Old Nov 14, 2008 | 07:22 PM
wildbill's Avatar
Could be the fooler is goin bad. You try just the Puck?
Old Nov 14, 2008 | 07:49 PM
It has never thowna code with just the puckbut then i get bored and add the fooler
Old Nov 14, 2008 | 08:39 PM
06 DIESEL's Avatar
You might have them hooked up backwards, try hooking them up the other way and see if it does it. I can not remember which is correct off the top of my head though.
Old Nov 14, 2008 | 09:14 PM
06MegaCTD's Avatar
mine is hooked up with the puck getting plugged into the head first, then the boost fooler, then the stock plug male end.
Old Nov 14, 2008 | 10:57 PM
dontneedtostroke's Avatar
i had mine plugged in the opposite, and i never had a code to speak of
Old Nov 15, 2008 | 10:44 AM
I have tried it both ways still gives me fits
Old Dec 20, 2008 | 07:14 PM
Tyber's Avatar
I had the same issue and what it turned out being was a bad power puck. One time I was just entering an off ramp and the puck threw a code and thn my truck shut down on me in the centre of the off ramp while i was doing 50km. Also the truck sometimes would not start back up after a shut down untill i disconnected it. My performance supplier ordered in a new one for me and I haven't had a problem in months
Oh and I am running it so that the boost fooler is connected to the factory wire harness
Old Dec 28, 2008 | 10:58 PM
kgeiger81's Avatar
A buddy of mine was having problems with his truck running a puck and a boost fooler. It didn't matter which way it was plugged in, he still got the same error code. When we tried the puck by itself along with the tuner and then the fooler by itself along with the tuner we had no problems at all. We ended up taking the boost fooler off for fear of burning up the turbo cause all it seemed to accomplish was run the boost up to 46 psi and raise the egt's too high.
|WYG|SS
Jul 26, 2015 11:18 AM
RexShoppe
Price Quote - Request A Price
Jun 16, 2015 02:48 PM
