CHECK YOUR COOLANT
Old Nov 13, 2008 | 06:14 PM
HOLYSMOKES's Avatar
NADM Member
Default CHECK YOUR COOLANT
Driving down the road last night. Check guages light came on.Motor overheating. WTF? I limped on back home. I noticed my overflow bottle was DRY. I opened the radiator cap. DO NOT RECCOMEND! I did it on a hunch I was out of coolant. Even under pressure, about 4 drops of coolant came out....that was IT! I noticed the TUBE RUNNING NEXT TO THE CAP TO THE OVER FLOW BOTTLE AT THE NIPPLE ON THE RADIATOR was leaking. THERE IS NO HOSE CLAMP ON THAT NIPPLE. I looked under and could see where coolant had been dripping.My advise......splurge. Spend the 24 cents and clamp it at the nipple. Just might save you on a motor.
FWIW.. Mine is an 06. After some research, this is a known issue. The trucks are hit and miss. Mark mine as a miss.
Old Nov 13, 2008 | 06:26 PM
06 DIESEL's Avatar
I know that mine does not have a clamp there, I guess I should put one on it. thanks for the FYI.
Old Nov 13, 2008 | 08:34 PM
MegaMan's Avatar
Yep, mine was leaking there too. I also had a leak at the heater hose where it connected to the block on the passenger side, down by the turbo. It was enough to see the level drop in the tank but not enough to see on the floor in the garage. Apparently it was blowing off, drying up, evaporating, whatever before I could find it. All i did to fix it was tighten the factory hose clamp. Been holding the fluid level ever since.
Old Nov 13, 2008 | 09:21 PM
wildbill's Avatar
So far, I've been lucky. Knock on wood.
Old Nov 13, 2008 | 11:21 PM
cbrahs's Avatar
none of them have clamps. I just put a black zip tie on it and cinched it up good
Old Nov 14, 2008 | 09:00 AM
DIESELDENT's Avatar
Thanks for the heads up ill be doing that tonight.
Old Nov 14, 2008 | 09:30 AM
staarma's Avatar
Yep, had to put a zip tie on my 04.5 too. The other thing you guys with the 06's might want to check are the coolant line connectors on the passenger side of the block under the turbo flange or thereabouts. Those are a known failure on the 06's. They will leak coolant down the block. I've been keeping an eye on my dad's 06 and so far he's good to go.
Old Nov 18, 2008 | 09:57 PM
corliss's Avatar
Thanks for the heads up Holysmokes, my Dodge has been fine but my Toyota Tacoma had lost some coolant at it's last service and it's been driving me crazy wondering why. I'm going to put a clamp on both vehicles, cheap piece of mind.
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
easttn12valve
Ford Powerstroke 2011-Up 6.7L
Mar 1, 2015 08:21 AM
moneypitk5
Feb 12, 2015 11:01 AM
97f-250
Nov 23, 2014 08:08 PM
