fuse #35
Old Nov 11, 2008 | 06:23 PM
dalton06's Avatar
Default fuse #35
what is this fuse? My outlook monitor is freezing up and flickers and the bullydog guy said to put the wire into number 35 to see if it will work better
Old Nov 11, 2008 | 07:21 PM
wildbill's Avatar
CCN Illumination. I'll see if I can find out what CCN stands for.
No good at schematics and the dealer isn't no help.
CCN= cabin compartment node. It's the new version of a body control module. The hardware/software for the CCN are actually made into the instrument cluster.
Old Nov 11, 2008 | 07:31 PM
dalton06's Avatar
cool I appreciate your help. So you think it will be ok to put the fuse tap in with the fuse for the outlook monitor power?
Old Nov 11, 2008 | 07:41 PM
wildbill's Avatar
Your welcome.
I ran my FASS off one of the keyed on fuses and it never threw any codes. So I don't see why you can't run the monitor off that particular fuse.
Old Nov 12, 2008 | 05:32 PM
dalton06's Avatar
well I tried that fuse and the monitor stayed on the whole time. Do you have any other fuse suggestions?
Old Nov 12, 2008 | 05:39 PM
wildbill's Avatar
You want the monitor to run with the key in the run position and acc?
Old Nov 12, 2008 | 06:39 PM
dalton06's Avatar
yes sir but when I connected it to 35, it stayed on even with the key in the seat
I need to find a 10amp fuse that has power with the key on and no power with it off. Any suggestions?
Old Nov 12, 2008 | 06:58 PM
wildbill's Avatar
I'll run out to my truck and see what fuse I'm running my gauges off of.
Old Nov 12, 2008 | 07:10 PM
dalton06's Avatar
my gauges are on a different one but I thought that was just to make them light up with the headlights.
wildbill's Avatar
OK, run position only, fuse #30. Run position and ACC, fuse #40
