Dying VP?
Old Nov 11, 2008 | 02:57 PM
cummins24's Avatar
Default Dying VP?
Last night I updated the adrenaline with the newest version of the dyno tune. So today I was driving home and decided to roll a little coal on the city folks, turned it on level 10 and hardly got any smoke or power at all. I turned it back to stock and laid into it, boost and everything was normal so it doesn't feel like its in limp mode and no codes were thrown. When I got home I killed the engine and then started it again about 15 minutes later because I've heard warm hard to start issues are related to the VP. It fired up like normal but I think I am going to put another tune on the ADR and check ADR connections under the hood and see what happens. Questions? Comments?
Old Nov 11, 2008 | 03:03 PM
Try the new comp tune
Old Nov 11, 2008 | 04:31 PM
cummins24's Avatar
This morning the dyno tune worked fine it just happened on my way home. I had the older version of the comp tune of it before and loved it so I'll probably switch back
I ran into town a little while ago and everything ran normal. I'm not sure what the deal was but I am still going to download a new tune and probably update the pulse for custom tuning
Old Nov 11, 2008 | 04:36 PM
You should be go to go
Old Nov 25, 2008 | 11:44 PM
recordcatch's Avatar
I'm no expert but I sweated through diagnosing/deciding a few months ago whether or not my VP44 was failing - 240,000 on the original. Based on all I learned - I concluded my VP44 was bad. The replacement (Blue Chip Diesel) cured the problem and improved performance and fuel mileage. Based on your description of the problem it seems unlikely you have a VP44 failure.
Old Nov 25, 2008 | 11:47 PM
Uncle Bubba's Avatar
Sounds to me like your lift pump is goin. I don't see any high pressure LP or fueling mods in your signature. If your runnin that box with the stock fueling system your starving your VP and it won;t last long turned up. Your literally runnin the VP dry if this is the case.
Old Nov 26, 2008 | 03:56 AM
Fishin2Deep4U's Avatar
From what I have found, the Adrenaline can cause too much duty cycle at high rpm. This in effect alters the timing, fuel volume and even fuel pressure.
This is why most trucks make more power on a lower level than on PL9 or PL10.
Also, lift pump pressure is not the cause. I know this as I have run over 40 psi into the VP44 through a modified 14mm inlet with no changes in power.
Dave
Old Nov 26, 2008 | 05:44 PM
piperca's Avatar
40 PSI into a VP??? That's looking for trouble! There is a valve that is set at 14 PSI (I think) that bleeds off the excess fuel, but most often the truck will have starting issues with pressures in the 20s.
I'm sure that too much pressure is not going to provide any additional performance over what you would normally get with a truck that is tuned properly; however, a lift pump that is supplying a less than adequate amount of fuel to the VP is certainly going to provide performance issues ... been there, done that! I noticed a remarkable difference in performance when I replaced my dead lift pump ... even more when I replaced my DEAD VP44 a few months later. Listen to what has been said before and check your fuel delivery system. A fuel pressure gauge can save you a lot of heartache and money!
Old Nov 26, 2008 | 07:05 PM
Mopar1973Man's Avatar
Here Here!
Old Nov 29, 2008 | 11:17 AM
dukeboy_318's Avatar
I second that one, you dont want anything over 25psi and anything less then 7 and thats from cummins and bosch themselves, anything more then 25 for a long period of time will reputure seals, if youre just doing a sled pull of strip run a few times a year and dont do any daily driving, you'll be fine at 40 psi but make sure you are ready to swap VP44s when it burns up.
