RPM's
Old Nov 11, 2008 | 01:48 PM
Ramanian's Avatar
Default RPM's
hey fellas, as always you guys helped me out on my Q's, and know i got another one. Everytime i floor it (GAS Pedal), or just plain ol romp om it, i notice that my tranny never hits redline or even close to it in any gears even with the overdrive off, but if i shift it manually it will, but that only gives me the first 2 gears. Its a 47re, and the tranny is basically stock from what i can tell. I mean is this normal. Does this happen to others with this tranny, or should i be worried about something. Plaese shine a light on this. I am considering a transgo shift kit too.
not all at once please. ha ha
Old Nov 11, 2008 | 11:18 PM
Thats pretty much normal.
Old Nov 12, 2008 | 12:33 AM
Ramanian's Avatar
well if its normal thats great, but also when im at around 38-39 mph it goes in and out of gear then finally shifts into overdrive around like 43-44, which i know is normal but dont like the whole gear engage/disengage feel i get at 38-39.
Old Nov 12, 2008 | 12:43 AM
What mods have you done to your truck?
I should have clarified that I have a 12V auto not a 24V.
Old Nov 12, 2008 | 12:44 AM
SixOhh's Avatar
governor pressure solenoid possibly?
Old Nov 12, 2008 | 01:33 AM
If Im not mistaken there is some sort of fix for the in/out of gear problem. A noise filter. DTT sells them.
Old Nov 12, 2008 | 10:43 AM
01quadcab's Avatar
just turn over drive off till you hit 55 and you wont have the problem
Old Nov 12, 2008 | 12:11 PM
SixOhh's Avatar
or you could be "white" about it and fix it instead of temporarily changing line pressure/ shift points.
Old Nov 12, 2008 | 12:59 PM
DIESELDENT's Avatar
i just used foil and a wire cover on the smaller red cable coming off the pass side battery to the alternator and it stoped doing that. worked the same as a noise filter.
Old Nov 12, 2008 | 01:35 PM
More explanation...what is a "wire cover"?
