More boost
Old Nov 5, 2008 | 10:41 PM
cummins24's Avatar
Default More boost
I'm wanting to get more boost out of my turbo. With the Adrenaline I've touched 30psi but I can't hold constant boost pressure over 20psi. Is the Edge boost elbow a decent investment or can I adjust the wastegate on a stock HX35?
Old Nov 5, 2008 | 10:52 PM
wildbill's Avatar
You can adjust it, be careful you don't go over 40lbs. Otherwise you'll blow a head gasket.
Old Nov 5, 2008 | 11:56 PM
stkdram55's Avatar
how do you adjust it??
Old Nov 5, 2008 | 11:59 PM
2500HeavyDuty's Avatar
juice grips
Old Nov 6, 2008 | 02:55 AM
Queeg's Avatar
You need a better turbo!
You can run the crap out f the hx-35 but the truth is if you torture it too much! It will die!
Anything more then 30 psi is bad!
If you want more reseach the j-hook! Simple fast! And works.
I killed my hy-35 hitting it to 35+ all the time! I scortched the shaft on it. It was a sexy blue color where the bearing were, and bent the backplat ( into a nice arch)
And wouldn't spin worth crap!
It had no excessive shaft play! Just torched it! I never ran it over 1350for more then a few seconds! And always cooled to 325 degrees before shut down!
With my new turbo I can barley get to 1300 trying! And can hit 42 psi no problem! No worries! No looking back
Just my 50 cents!
Old Nov 8, 2008 | 03:28 PM
cummins24's Avatar
I'm not looking to get insane pressure, mid 20s would be nice. How hard is it to adjust and what all do I need to do to adjust it?
Old Nov 8, 2008 | 05:02 PM
01quadcab's Avatar
with the hx you need a adjustable elbow. I think I have one from my edge setup as I had to jhook my hy. if you need it let me know... I think I still have it
Old Nov 8, 2008 | 06:08 PM
DslDeamon's Avatar
while were on the subject of boost what does the boost of a dodge 2500 2008 6.7 run for boost stock?
Old Nov 8, 2008 | 10:08 PM
cummins24's Avatar
Does the Edge boost elbow have a smaller opening than the stock elbow?
Old Nov 9, 2008 | 02:28 AM
01quadcab's Avatar
i think so
