fuel issues
Old Nov 4, 2008 | 08:51 AM
TXPRIDUALLY's Avatar
Default fuel issues
ok so heres the deal....im a marine, im in iraq, and on my base there is a battalion of Iraqi Army soldiers....the Iraqi soldiers have a 2006 F-350 6.0L. they came to our Motor T shop today while i was fixing a piece of gear and said they had water in the fuel. well im no mechanic, i had them drain the fuel tank, which they did, but they still have water in the lines, i looked at it, the fuel going into the filter bowl is almost like a, coffee with cream color, i need to find out if its possible to drain the lines, or are they pretty much f#kd? any help with this would be GREATLY appreciated, not only by myself, but also by our Iraqi brothers-in-arms.
Old Nov 4, 2008 | 09:20 AM
06 DIESEL's Avatar
I am no Pawerstroke mechanic but I bet you could disconect the injector lines from the injectors and blow them out backwards, just make sure that you do nto try to blow backwards through the fuel delivery pump (CP3 on GM and Dodge, not sure bout the Powerstroke). Then re-prim the system with good fuel and you should be good to go.
Old Nov 4, 2008 | 09:30 AM
could you just disconnect the injector lines and let the fuel pump just pump it all out?
Old Nov 4, 2008 | 11:21 AM
06 DIESEL's Avatar
You could I guess but the fuel pump needs lubrication so I would let it pump the good fuel through until all of the old is out then reconect the lines. Make sure to clean-up the spilled fuel though to try to prevent a fire.
Old Nov 4, 2008 | 11:34 PM
this is IRAQ bro....whats gonna burn? the dirt? oh NO
Old Nov 5, 2008 | 12:01 AM
stkdram55's Avatar
well the PS's dont have an Inj. pump they are called HEUI injectors and are run off of high pressure oil, so my suggestion would be to replace the lines and be done with it...
Old Nov 5, 2008 | 12:12 AM
once again.....IM IN IRAQ guys....i cant just run over to the nearest dealership
Old Nov 5, 2008 | 01:06 AM
stkdram55's Avatar
My bad i would remove the lines and blow them out with compressed air (i hope you guys at least have that) and then start dumping good clean diesel down thru them to try and clean them out as good as possible and then hook back up and enjoy
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
J. Nick
Apr 25, 2015 05:01 PM
12Valvepower01
Mar 30, 2015 03:41 PM
moneypitk5
Feb 12, 2015 11:01 AM
