diesel in pan
Old Nov 3, 2008 | 09:17 PM
bigt8910's Avatar
Default diesel in pan
need help!!! check engine light on. have had problem in the past. i would unplug power puck and light would clear. po251 code. this time there was 7 gallons give or take in oilpan. i unpluged the puck and changed oil, the light will not clear and the level on the dipstick is slowly rising. this sounds like injector or pump problem. any ideas? i am working a construction job in the middle of nowhere and there is no garage close. any ideas would be appreciated.
bigt8910
Old Nov 3, 2008 | 09:23 PM
wildbill's Avatar
Got a faulty injector or injectors. Should call a tow vehicle otherwise if you keep driving it, you may end up with a scored cylinder=new engine.
Old Nov 3, 2008 | 09:24 PM
06 DIESEL's Avatar
Did it smell like Diesel when you changed the oil? If so then you have bad injectors, I hate to say it but if your oil is multiplying that is most likely the cause.
Old Nov 3, 2008 | 09:50 PM
Injector Issue
Old Nov 3, 2008 | 10:19 PM
Uncle Bubba's Avatar
New injector washer/seal fixed this up on mine a few years back. If it's just leaking a little bit you really not gonna hurt to much. Theres not a huge difference between the diesel fuel and the motor oil anyway. Just a little thinner viscosity.
But be it a bad inlector or just the seal it is almost a certainty that it will be coming from that area on the engine.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Strictly Diesel
Strictly Diesel
Jun 30, 2015 06:48 PM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
