Best location for tranny pan drain?
Old Nov 1, 2008 | 05:10 PM
piperca's Avatar
Default Best location for tranny pan drain?
I am getting ready to tear into my truck and do a tranny fluid change and am going to put a drain plug in the pan while I'm at it ... what's the best location?
Also, instead of dropping the pan to drain the fluid, since I am puting in the drain plug, I thought I might drill the hole for the plug to drain the fluid ... what do you think?
Old Nov 1, 2008 | 11:40 PM
wildbill's Avatar
I believe your going to have to get a bung/bolt combo and weld the bung to the pan cause the pan is too thin to cut threads for a plug. It would go in the center of the pan.
Old Nov 6, 2008 | 03:11 AM
Queeg's Avatar
In the bottom......
Ok had to say it!
I put mine in the bottom towar the rear of the truck,
If you get the nut bolt type, use some silicone with it! Mine leaked no matter how tight I got it! Your best bet it to weld a nut/bung to it!
It will also help drain all of it out. With mine it leaves a 1/2" of fluid in there!
Old Nov 14, 2008 | 10:56 PM
LOGANSTANFORTH's Avatar
you can get a deeper pan for cheap.....
Old Nov 15, 2008 | 12:08 AM
You do not need to cut any threads:
B&M DRAIN PLUG-Dodge Cummins and Ford Power Stroke Diesel Truck Accessories - Geno's Garage (which BTW is a really good price - seen them for double that on other sites)
I would say somewhere toward the back of the pan (away from the filter).
Aug 13, 2015 10:10 AM
rodbuilder
Jun 26, 2015 12:48 AM
98cummins
Jan 29, 2015 08:23 PM
BCOWANWHEELS
Wanted To Buy (WTB) - Used
Jan 7, 2015 03:42 PM
Nov 7, 2014 05:40 PM
