Fuel leak help
Old Nov 1, 2008 | 03:40 PM
jeepdude's Avatar
Default Fuel leak help
I've got a leak on top of my fuel filter where the wires go in the top for the fuel heater?? . Anybody know how to fix that? thanks
Old Nov 1, 2008 | 11:44 PM
wildbill's Avatar
O-ring or gasket replacement.
Old Nov 5, 2008 | 07:35 AM
dukeboy_318's Avatar
thats bout the only way to fix it except to replace the whole thing.
Old Nov 5, 2008 | 08:07 AM
Whit's Avatar
Site Mascot
yes its just an o-ring........simple fix just make sure to coat the new o-ring in fuel so it wont roll on the way in.......also dont get an over the counter o-ring as it will most likely be Buena rubber and the ULSD will swell it up and degrade quickly...................Viton or EPDM is the best bet, if you have no source for these than get one from Chrysler
Old Nov 6, 2008 | 03:15 AM
Queeg's Avatar
Very expensive fix = fass or airdog, and bypass the whole thing!
2cents here!
Old Nov 6, 2008 | 06:52 AM
2cents here!
i agree, and dont put a tonj of pressure on it or itll crack the aluminum housing like i did and then you must got for the airdog/fass
Old Nov 6, 2008 | 07:54 AM
feroxman's Avatar
My outfit is leaking at the grommet where the wires go into the top of the heater. Any ideas?
What are these fass or airdog comments referring to?
Any ideas would be hot!
Thanks.
Old Nov 7, 2008 | 09:12 AM
they are an aftermarket lift pump and filter converision, much better then stock they run 500-700 bucks. new grommet is the only way to fix it
Old Nov 7, 2008 | 11:22 AM
feroxman's Avatar
What are the after market options names? I am new to the conversion idea. Any suggestions would be very appreciated.
Thanks in advance.
Old Nov 7, 2008 | 01:02 PM
Google FASS filtration or Airdog Systems and you're on the way.
