weird
Old Oct 30, 2008 | 05:25 PM
89silverbullet's Avatar
Default weird
I have a 97 cummins. I will turn the key and get the wait to start light wait for it to go off and, turn the key and it will hit or miss start or just keep turning over. Could the be a grid problem or a bad starter. PS what is the voltage on youse guys truck before turning the key? thanks in advance.
Old Oct 30, 2008 | 05:29 PM
Whit's Avatar
Site Mascot
are the grids pullin some serious amps on the gauge whilst yer settin there waitin??
sounds like a fuel problem to me......if it fires it should stay runnin
Old Oct 30, 2008 | 05:40 PM
xzaq103's Avatar
FormerVendor
How cold is it down there?
I agree with Whit sounds to me like a fuel issue is your shut off solenoid pulling up completely?
Old Oct 30, 2008 | 09:18 PM
Racer9's Avatar
Or possibly idle too low. Ram Diesel Problems
If you push the throttle a little, and it fires right up, adjust the idle.
Old Oct 30, 2008 | 10:19 PM
funny you mention that... If i press the throttle in just enough it will fire better. it is about 45 degrees here give or take 10 degrees. I have noticed that the amps are pulled down during the Wait to start sequence. Onece it starts it idles low and comes up.
Old Oct 31, 2008 | 02:59 PM
xzaq103's Avatar
FormerVendor
What is the idle at with A/C on MAX in Drive when the truck is warm?
Old Oct 31, 2008 | 03:11 PM
MotorOilMcCall's Avatar
Mine does the same thing, just not as bad... I think the injectors are leaking, of course 300K miles will do that. Mine fires every time, just takes a minute or two... If it gets really bad I'll have the injectors pop tested to see how they are running.
Old Nov 2, 2008 | 09:19 PM
my idle i would guess is at 500 rpms
Old Nov 2, 2008 | 10:17 PM
Benjamin's Avatar
Bombardier
in the cold i would adjust the idle to 700-800 rpm in drive with the a/c on. that should be your problem.
Old Nov 3, 2008 | 08:45 AM
its a stick by the way
