ABS
Old Oct 27, 2008 | 05:00 PM
zjohnsonua's Avatar
Default ABS
This weekend i managed to blow both wheel cylinders at once somehow and limped it home with scarce brake usage. At some point during that limping period the ABS light came on. After replacing the wheel cylinders and topping the reservoir off (never got low enough to suck air), the light is still on. Any ideas how to get it to go off?
Old Oct 27, 2008 | 06:52 PM
keithduke01's Avatar
the abs controller will lose its memory after two minutes of the batteries being unhooked if memory codes are the problem
Old Oct 28, 2008 | 06:20 PM
zjohnsonua's Avatar
the batteries never got disconnected, any other ideas, i hate having odd lights on
Old Oct 28, 2008 | 06:52 PM
Whit's Avatar
Site Mascot
do a normal brake bleed on all 4 and she should be OK
always start with the furtherest away point and work in
Old Oct 28, 2008 | 09:46 PM
hughesis21's Avatar
zjohn. i think what keith was tellin you to un hook your batteries for 2 mins then hook em back up the light should go out. your truck has memory of your brakes being bad but if you un hook the batteries itll forget all about that limp home with no brakes
Old Oct 29, 2008 | 10:19 AM
zjohnsonua's Avatar
Thanks hughesis, had a bit of a brain fart haha. Will try the battery disconnection truck this afternoon and if that doesn't do the truck then the brake bleed will get done this weekend. Ill post up here if one works or if other solutions are needed. Thanks yall for the info so far
Old Nov 21, 2008 | 02:44 AM
davo79's Avatar
pull the fuse its easier then the cables
cjt8569
Sep 29, 2015 06:39 PM
asajay
10
Sep 8, 2015 10:40 PM
Radioking1777
Jun 9, 2015 04:13 AM
Gitana
Nov 25, 2014 06:25 PM
ValleyF250
Nov 1, 2014 07:56 PM
