Coolant Temp. Sensor
Old Oct 24, 2008 | 06:58 AM
Bigfury's Avatar
Default Coolant Temp. Sensor
Can someone explain to me how the coolant temperature sensor works?Reason being, I have thoughts (this always leads into some kind of a project) of installing one in the fuel tank.With hopes of using it via a relay to run a 12v pump to keep the biodiesel warm in the winter.If this temp. sensor is a on/off style switch I can use it to monintor the fuel temp.Simply by hooking it to a relay to run a pump to move engine coolant into the fuel tank, all by itself ( I HOPE ).Thanks in advance.Hopefully I do not post this in the wrong place.Have a great weekend everybody.
Old Oct 25, 2008 | 11:37 AM
welderboy250's Avatar
ur temp sensor isnt a switch for sure cause if it were the gauge wouldnt change with temperature, it would be in one of 2 places and thats it. there are things that may work for u such as thermodiscs or maby some kind of aquastat or somethin. part of the key will be to have it set for the right range. u ned to do somethin similar to how a boiler furnace works where if the temp gets to cold the switch closes and if it gets too hot the switch opens.
Jet A Fuel
Aug 3, 2015 10:45 AM
Bull Grunt
May 15, 2015 09:55 AM
Bull Grunt
May 3, 2015 06:38 AM
robbyS
Apr 16, 2015 02:22 PM
mule97
Dec 12, 2014 05:05 AM
