Best place to read fuel pressure?
Old Oct 23, 2008 | 09:16 PM
MegaMan's Avatar
Default Best place to read fuel pressure?
It's time for a fuel pressure gauge and I've been reading old threads, seen a lot of good info. What's the best place to read fuel pressure where I'll be able to monitor the lift pump performance? Is that the main thing we need to watch on our trucks is lift pump output? I'm talking basically stock here, no heavy bombs.
Old Oct 23, 2008 | 09:39 PM
Nitelord's Avatar
Mine is tapped right off the OEM fuel filter cap.
Old Oct 23, 2008 | 11:52 PM
2500HeavyDuty's Avatar
in between the fuel filter and cp3 pump
Old Oct 24, 2008 | 06:40 AM
06 DIESEL's Avatar
Here is where mine is tapped at, the braided line is the gauge.
Old Oct 24, 2008 | 04:03 PM
MegaMan's Avatar
06 Diesel, I like that setup you have, seen pictures of a few other ones done like that.
Thanks.
Old Nov 3, 2008 | 10:16 AM
cdennyb's Avatar
Default if you still have the rubber hose...
You can insert a tee between the filter housing and come off it to a fuel pressure isolator diaphram. Don't run a wet line into the cab... I'm really not concerned that it will be a fire hazard... it just smells the cab up really bad for some reason... hmmm. diesel...
db
Old Nov 13, 2008 | 12:53 PM
madhat's Avatar
I have mine at the CP3 the same way that 06 has his. This way, I know what kind of FP my CP3 is reading.
Dbleo351
Nov 20, 2016 09:34 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
