stack
Old Oct 23, 2008 | 03:45 PM
wilke12V's Avatar
Default stack
im getting a 5" stack for my truck, i want it off center to the right so it will line up. is there anything special i need to do besides get a 90 and a straight pipe and cut a hole in the bed?
ive also seen the exhaust come out of the hood, how and what is that?
Old Oct 23, 2008 | 04:32 PM
stkdram55's Avatar
you mean you want the stack to come right up where the exhaust runs normally, then yes you will need a a piece of straight pipe to come from your down pipe and i would recomend using flexpipe also if its a regular cab i would run the flex right off the down pipe then to the straight to the 90 and up to the stack. I'll go take a picture of mine to show you some ideas
Old Oct 23, 2008 | 04:55 PM
stkdram55's Avatar
here is mine and how i got attached the bed
Old Oct 24, 2008 | 02:52 PM
wilke12V's Avatar
where can i get the flex pipe, and will it need to be 4 or 5"
Old Oct 24, 2008 | 03:10 PM
stkdram55's Avatar
any exhaust shop should be able to get it for ya, you will only need 4" since the rest of your exhaust is 4".
The order should be-Down pipe then to either a little piece of straight then to flex or just straight to flex, then enough straight to get you where the 90 will go up and to your bed then either attach the stack to the 90 if it is long enough or you may need to put another short section of pipe on the 90 to then go to the stack
Old Oct 25, 2008 | 12:10 AM
wilke12V's Avatar
well i got it. its short tho when set in the bed it only goes about 3/4 of the back window. so my last question is how do i get the whole thing to seal. or do i just slide the stgack over the top of the exhaust?
Old Oct 25, 2008 | 12:48 AM
stkdram55's Avatar
you might need to add a little piece of pipe to get the stack up higher because your gonna have alot of cab noise when your driving but you may like that.
to seal it you'll need some exhaust clamps like this one
that should seal it up good
Old Oct 25, 2008 | 08:47 PM
wilke12V's Avatar
thanks
firstgenpr
Basement Enterprises
May 26, 2015 01:08 PM
hollywoodbusa
Wanted To Buy (WTB) - Used
Feb 22, 2015 08:05 PM
hollywoodbusa
For Sale
Feb 22, 2015 08:03 PM
ramrunner01
Jan 19, 2015 05:01 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
