Chevy/GMC Duramax 06-07 LBZ Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines
dtc codes
Old Oct 23, 2008 | 02:21 PM
Texas Rocket's Avatar
Default dtc codes
My buddy has an 07 classic and threw a code of 0087. gave it fuel and no power what so ever. Please help with this one. Thanks, TX Rocket Also does anybody have a sheet of codes that i can get Thanks
Old Oct 23, 2008 | 06:50 PM
2500HeavyDuty's Avatar
Www.dieselbombers.com/codes.php
I can't look it up but it prolly nothing major
Old Oct 23, 2008 | 06:56 PM
Thanks, Dan-o
Old Oct 23, 2008 | 07:05 PM
No problem bud.
Old Oct 24, 2008 | 09:46 AM
jpowel29's Avatar
P0087 is a Fuel Pressure Rail code. The truck's fueling system is not able to deliver the commanded rail pressure. What mods have been done to the truck? What fuel tune was he trying to run. Sometimes the FPR shim mod will help eliminate this code.
Old Oct 24, 2008 | 07:57 PM
could be as simple as a FF change
Old Oct 24, 2008 | 09:40 PM
He's got a quad, and running the 50 horse tune. He has had this problem before. He has 22 percent left on the ff, i told him to change filling stations he is getting crappy fuel. This has happened about 4 times already and everytime he changes his ff it goes away.
Old Oct 25, 2008 | 01:17 PM
Oilfield_Mafia's Avatar
I would never go by the % on the dashboard readout for the fuel filter bud. I change my fuel filter every other oil change.. No matter what the dashboard reads. If that dont fix the problem, you can get a fuel valve shim. Its very easy to install. That should help some.
Old Mar 11, 2009 | 10:07 AM
blksmok's Avatar
When you put a programmer on the truck, the DIC info goes out the window. If he's at 22% on the FF, I'm sure it's nothing more than a FF that is overdue for a change.
asajay
Sep 10, 2015 12:08 AM
longhorn12
6.7L Performance
Aug 29, 2015 01:28 PM
schwier94
Mar 8, 2015 06:09 PM
KimberlysTruck
Mar 5, 2015 06:28 PM
Altonlee
9
Oct 8, 2014 02:31 PM
