4k kit
Old Oct 23, 2008 | 12:11 AM
kekrocks's Avatar
Default 4k kit
Is there a 4k kit for a VP44 does changing the plungers do this?
Old Oct 23, 2008 | 12:14 AM
stkdram55's Avatar
no to do a 4k you have to have a box or programmer, im pretty sure smarty has a tune to get us to 4k and i know Blue Chip Diesel has the Redline Box which is adjustable from 3k-32k and up to 4k RPM's but you will also need HD valve springs to run 4k's
Old Oct 23, 2008 | 09:57 AM
dukeboy_318's Avatar
the hot unlock code for the edge juice will run it up to 4k as well
Old Oct 23, 2008 | 10:30 AM
kekrocks's Avatar
i was told it only goes up to 3200 and then defuels
Old Oct 23, 2008 | 10:36 AM
nope the email that edge sent me told me that the standard juice goes up to 3200 before defueling, the hot unlock code for 100 bucks moves it to 4k at which defuel begins.
btw, TST Drag verison of the powermax tuners also has a 4k tune on it, but you must specify it to mark when ordering it.
Last edited by dukeboy_318; Oct 23, 2008 at 10:36 AM. Reason: Automerged Doublepost
Old Oct 23, 2008 | 11:15 AM
24Vs already have the 60 pound springs.
Old Oct 25, 2008 | 01:52 PM
turbomar's Avatar
Exclamation
[QUOTE=dukeboy_318;227517]nope the email that edge sent me told me that the standard juice goes up to 3200 before defueling, the hot unlock code for 100 bucks moves it to 4k at which defuel begins.
You guys got me interested. I have the edge/juice with power level 6 unlocked. So, I went out and tried the ref limiter on all power levels and it limits the revs @ 3450rpm on all power levels, even on level "0" which is the stock level. I assume the juice rev limiter is also active in stock mode since u guys say the the stock rev limit is 3200rpm, right?
Old Oct 26, 2008 | 09:11 AM
[quote=turbomar;228227]
ive found that even in stock mode, the safety features are enabled, especially the cold engine protection and egt features. also, i know on mine, that you can adjust the rev limiter, mine was set on 3400 when i first got it, i increased that to 3900 and i easily hit that while still at full power. If you go under the menu where it has the juice configuration, then go to "Max rpm", you can change it.
Old Oct 27, 2008 | 11:51 AM
AHolt's Avatar
Hamilton has a sale on 110 pd valve springs going
on now. $199. you can,t beat that. I,m running
them in my truck,and just bought another set
for my spare head.
Old Oct 27, 2008 | 12:13 PM
DB Admin's Avatar
Banned
You can get an ADD for Less than $50 and fuel till you blow up if you want
